Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
UPS DeviceUPS Device
UPS Device
UPS Device
Monitor your Uninterruptible Power Supplies (UPS) over SNMP
Extension
Free trialDocumentation
UPS Overview dashboardUPS metrics collectedUPS extension configuration
  • Product information
  • Release notes
Overview
This extensions collects important UPS infrastructure metrics to monitor the health and reliability of devices. Metrics are collected through SNMP get polling
Use cases
  • Check UPS battery conditions such as charge or time remaining
  • Detect device anomalies and avoid data center outages
Compatibility information
  • Most UPS vendors and models (UPS-MIB supported)
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Extension content
Content typeNumber of items included
metric query
1
generic relationship
1
document dashboard
1
dashboards
1
screen layout
1
metric metadata
28
generic type
1
Feature sets
UPS Alarms Presentsnmp.ups.AlarmsPresentThe present number of active alarm conditions.Count
UPS Output Frequencysnmp.ups.OutputFrequencyThe present output frequency (0.1 Hertz).Count
UPS Output Num Linessnmp.ups.OutputNumLinesThe number of output lines utilized in this device. This variable indicates the number of rows in the output table.Count
UPS Bypass Frequencysnmp.ups.BypassFrequencyThe present bypass frequency (0.1 Hertz).Count
UPS Bypass Num Linessnmp.ups.BypassNumLinesThe number of bypass lines utilized in this device. This entry indicates the number of rows in the bypass table.Count
UPS Input Line Badssnmp.ups.InputLineBads.countA count of the number of times the input entered an out-of-tolerance condition as defined by the manufacturer.Count
UPS Input Num Linessnmp.ups.InputNumLinesThe number of input lines utilized in this device.Count
UPS sys Up Timesnmp.ups.sysUpTimeThe time (in hundredths of a second) since the network management portion of the system was last re-initialized.Count
UPS Line Bypass Voltagesnmp.ups.line.BypassVoltageThe present bypass voltage (RMS Volts).Count
UPS Line Bypass Currentsnmp.ups.line.BypassCurrentThe present bypass current (0.1 RMS AMPS).Count
UPS Line Bypass Powersnmp.ups.line.BypassPowerThe present true power conveyed by the bypass (WATTS).Count
UPS Alarm Timesnmp.ups.alarm.AlarmTimeThe value of sysUpTime when the alarm condition was detected.Count
UPS Battery Statussnmp.ups.BatteryStatusThe indication of the capacity remaining in the UPS system's batteries - unknown(1), batteryNormal(2), batteryLow(3), batteryDepleted(4)Count
UPS Seconds On Batterysnmp.ups.SecondsOnBatteryIf the unit is on battery power, the elapsed time since the UPS last switched to battery power, or the time since the network management subsystem was last restarted, whichever is less. Zero shall be returned if the unit is not on battery power.Second
UPS Estimated Minutes Remainingsnmp.ups.EstimatedMinutesRemainingAn estimate of the time to battery charge depletion under the present load conditions if the utility power is off and remains off, or if it were to be lost and remain off.Minute
UPS Estimated Charge Remainingsnmp.ups.EstimatedChargeRemainingAn estimate of the battery charge remaining expressed as a percent of full charge.Percent
UPS Battery Voltagesnmp.ups.BatteryVoltageThe magnitude of the present battery voltage (0.1 Volt DC).Count
UPS Battery Currentsnmp.ups.BatteryCurrentThe present battery current (0.1 Amp DC).Count
UPS Battery Temperaturesnmp.ups.BatteryTemperatureThe ambient temperature at or near the UPS Battery casing (degrees Centigrade).Count
UPS Line Output Voltagesnmp.ups.line.OutputVoltageThe present output voltage (RMS Volts).Count
UPS Line Output Currentsnmp.ups.line.OutputCurrentThe present output current (0.1 RMS AMPS).Count
UPS Line Output Powersnmp.ups.line.OutputPowerThe present output true power (WATTS).Count
UPS Line Output Percent Loadsnmp.ups.line.OutputPercentLoadThe percentage of the UPS power capacity presently being used on this output line, i.e., the greater of the percent load of true power capacity and the percent load of VA.Percent
UPS Line Input Frequencysnmp.ups.line.InputFrequencyThe present input frequency (0.1 Hertz).Count
UPS Line Input Voltagesnmp.ups.line.InputVoltageThe magnitude of the present input voltage (RMS Volts).Count
UPS Line Input Currentsnmp.ups.line.InputCurrentThe magnitude of the present input current (0.1 RMS AMP)Count
UPS Line Input True Powersnmp.ups.line.InputTruePowerThe magnitude of the present input true power (Watts).Count
Related to UPS Device
SNMP Traps logo
SNMP Traps
Supplement network monitoring with event-based data reported via SNMP Traps.
Full version history
ReleaseDate
  • Add platform dashboard
  • Add metric metadata such as sourceEntity
  • UPS battery and power input/output/bypass metric collection
  • Overview dashboard
  • Custom topology rules
Dynatrace Hub
All (814)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityDigital ExperienceBusiness Observability
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Analyze abnormal system behavior and performance problems detected by Davis AI.
Logs logo
Logs
Security Investigator logo
Fast and precise forensics for security and logs on Grail data with DQL queries.
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Davis Anomaly Detection logo
Detect anomalies in timeseries using the Davis AI
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Automate tasks in your IT landscape, remediate problems, and visualize processes
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Overview logo
Security Overview
Get a comprehensive overview of the security of your applications.
Code-Level Vulnerabilities logo
Detect vulnerabilities in your code in real time.
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub CoPilot Coding Agent logo
GitHub Copilot Custom Agent
Observability for Developer on Jetrains logo
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
