Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Cost & Carbon OptimizationCost & Carbon Optimization
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
App
Try in PlaygroundDocumentation
Cost & Carbon Optimization overview page summarizes carbon emissions, energy consumption, cloud costs, and optimization targets.
  • Product information
  • Release notes
Overview
Cost & Carbon Optimization reports carbon emissions and public cloud costs for all hosts monitored by OneAgent, and provides detailed carbon emissions and energy consumption metrics for Kubernetes infrastructure monitored by Dynatrace. It also provides actionable guidance for how to reduce their overall IT carbon footprint. Cost and Carbon Optimization is for users who want to:
  • Analyze granular IT greenhouse gas emissions to support carbon reduction initiatives at data center, host, Kubernetes infrastructure, and application levels.
  • Democratize cost data to provide actionable cost management insights to engineering and operations teams.
  • Combine sustainability and cost optimization initiatives to reduce redundant effort.
Use cases
  • Cost reporting and allocation
  • Carbon reporting and allocation
  • Carbon reduction
  • Usage optimization
  • Kubernetes infrastructure carbon optimization
  • Cost anomaly management
Get started
  1. Review user and workflow authorization permissions and prerequisites before installing the app
  2. Open Cost & Carbon Optimization and select Settings.
  3. To report carbon emissions, turn on Enable energy and emission data generation.
  4. To report cloud costs, enable external request URLs for the relevant cloud vendors and turn on Enable price list cost data. If you use GCP, enter your GCP API Key—see documentation for more details.
  5. Review the settings for idling optimization and sizing optimization.
  6. Optionally, select one of your configured business events as your business health performance indicator.
Details
  • To report carbon emissions, the app translates utilization metrics—including CPU, memory, disk, and network I/O—into energy consumption (kWh) and CO2 equivalents (CO2e).
  • To report cloud costs, the app uses the host instance type to calculate costs using public list price data from AWS, Azure, and GCP, refreshed every 24 hours.
Cost and carbon calculations are allocated to host instances and summarized by data center. Optimization recommendations are automatic and focus on idle and under-utilized instances.
The Sustainable Digital Infrastructure Alliance (SDIA) has certified that the “…calculations and methodology used are in line with the best available scientific approach, meeting relevant reporting requirements. Dynatrace meets our requirements for transparency, enabling customers to understand the calculations and to recreate the results for independent verification.”
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Full version history
ReleaseDate
Minor improvements & updates.
Improvements
  • Minor improvements & updates.
Improvements
Improvements
Bug fixes
  • An issue with a Playground navigation link has been corrected
  • An issue with overview tiles loading incorrectly has been corrected
Improvements
Improvements
  • App settings now directs users to change outbound connections settings in the Gen3 Settings app.
  • Permission-related error messages now direct users to the permissions listing in the Hub for additional
  • Avoid duplication of carbon data by prioritizing OneAgent data over API data when processing Kubernetes data.
Bug fixes
  • An issue with the Take Workflow Ownership in Settings has been addressed.
Bug fixes
  • An issue with energy/carbon calculation with Kubernetes API deployments has been addressed. Clusters monitored with Kubernetes platform monitoring that have >1000 namespaces may report a higher energy/carbon footprint as a result of this change.
  • An issue with Kubernetes processing in extremely large environments has been addressed.
Bug fixes
  • An issue that causes the app to crash when changing the timeframe multiple times in quick succession has been resolved.
Improvements
  • The Kubernetes calculation workflow has been improved to address the processing of large clusters with high volumes of nodes and namespaces.
Bug fixes
  • An issue that caused a crash when searching for KPIs in Cost & Carbon settings in environments with massive numbers of event types has been corrected.
Improvements
  • The Cost & Carbon Optimization app now supports our customers’ sustainability and optimization efforts with granular real-time emissions reporting and analytics for Kubernetes. Customers can now measure the energy consumption and carbon footprint of their Kubernetes infrastructure and leverage this with utilization information from the Dynatrace Kubernetes app to measure sustainability goals and optimize energy, costs, and waste.
  • A new Kubernetes explorer interface allows you to understand the energy and carbon footprint of Kubernetes clusters and namespaces.
  • The app leverages information from the Dynatrace Kubernetes platform monitoring to calculate energy and carbon, without the need for installation of additional complex Kubernetes plug-ins or configurations.
  • The app leverages the existing, certified energy and carbon calculation algorithms to ensure that measurements are accurate.
  • Kubernetes metrics are used to correlate the carbon footprint with the size of the cluster or node to identify areas for potential optimization
  • The app provides automatic comparisons of time periods to quickly determine whether sustainability or optimization efforts are having the desired effect.
  • One-click navigation between the Cost & Carbon Optimization and Kubernetes app allows you to inspect resource requests and limits, quotas, or idle workloads/jobs that reserve resources but run infrequently.
  • Kubernetes energy and carbon data is stored in Grail to facilitate custom Notebooks and Dashboards to report on the data in ways that match your organizational needs. Data from the Cost & Carbon Optimization app can be easily merged with data from our Kubernetes and Host & Infrastructure apps through custom notebooks and dashboards.
Improvements:
  • The Cost & Carbon overview page has been redesigned to provide a more streamlined view of carbon emissions, energy consumption, and cloud costs. Costs are now presented with an annual run-rate in addition to consumed costs (based on cloud list prices), and change metrics are presented more concisely as a value and a % change indicator.
Improvements:
Improvements:
  • Workflow scheduling has been improved to account for greater calculation workloads.
Bug fixes
  • An issue with the public cloud costs tiles on the overview page was resolved. Data in the underlying bizevents is unaffected, but users may see an increase in costs on the Overview page.
  • An issue with settings that causes the app to crash upon startup has been addressed.
Bug fixes
  • An issue with undefined cluster names has been resolved, and undefined clusters will now be stored with an "Unknown" name in the relevant Carbon Kubernetes business event.
Bug fixes:
  • Resolved an issue with the energy.measurement.cpu_wasted and energy.measurement.total_wasted properties in the Carbon Kubernetes events. Values for these metrics will now be populated with this release.
  • Resolved an issue with the Carbon Kubernetes semantic dictionary to consolidate the monitoring mode properties. The monitoring.mode property will be removed and k8s.monitoring_mode will be the attribute used to capture the monitoring mode reported by Dynatrace.
Improvements:
  • The Carbon Intensity (CI) values used by the Cost & Carbon Optimization app to calculate carbon.emissions metrics are updated with current values and may result in changes to the carbon measurements for on-premise hosts. Customers using newer GCP locations (europe-north2, europe-west12, me-central1, me-central2, africa-south1) will also see changes in carbon emissions metrics. Please see our heads-up announcement for full details on the change, and the values and % change for each country affected: https://dt-url.net/carbon-intensity-change
Bug fixes:
  • An internally-identified issue with Kubernetes energy/carbon calculation has been resolved. Users may see a minor change in Kubernetes carbon measurements, and engineering analysis indicates that the change will be very minimal.
Bug fixes
  • An issue that caused the app to crash when opening the Overview page has been identified and resolved.
Bug Fixes:
  • An issue with wasted energy calculations for cloud hosts was resolved.
  • An issue with carbon workflow timeouts was addressed for tenants with a high number of monitored hosts.
Improvements:
Carbon support for Dynatrace Kubernetes platform monitoring + Full-Stack observability is now generally available. Customers using Dynatrace Kubernetes platform monitoring + Full-Stack observability can now measure energy and carbon emissions of their Kubernetes infrastructure using the Cost & Carbon Optimization app. Business events are generated hourly for Kubernetes clusters and namespaces and can be reported on using custom DQL and dashboards using filters on:
event.type == "carbon.measurement.k8s.namespace" event.type =="carbon.measurement.k8s.cluster".
Please refer to the semantic dictionary for more information on the new events: https://docs.dynatrace.com/docs/shortlink/semantic-dictionary-business-analytics#carbon-kubernetes-cluster-events . Additional information about the support can be found here in the documentation: https://docs.dynatrace.com/docs/observe/business-analytics/apps/cost-and-carbon-optimization#get-started--concepts . No additional configuration is required, and Kubernetes Carbon business events will be automatically generated with existing Carbon business events for other OneAgent-monitored hosts.
Improvements
  • Permissions-related error messages have been improved to provide more user guidance when user actions fail and when workflow errors occur.
  • Carbon support for Dynatrace Kubernetes platform monitoring + Full-Stack observability is now generally available. Customers using Dynatrace Kubernetes platform monitoring + Full-Stack observability can now measure energy and carbon emissions of their Kubernetes infrastructure. Business events are generated hourly for Kubernetes clusters and namespaces and can be reported on using custom DQL and dashboards using filters on: event.type == "carbon.measurement.k8s.namespace"; event.type=="carbon.measurement.k8s.cluster". Please refer to the semantic dictionary for more information on the new events: Business Analytics — Dynatrace Docs . No additional configuration is required, and Kubernetes Carbon business events will be generated with existing Carbon business events for other OneAgent-monitored hosts.
Improvements
  • Permissions-related error messages have been improved to provide more user guidance when user permissions or workflow authorization settings are missing.
  • Improved the fidelity of carbon measurements on the overview page by increasing the decimal places shown for smaller measurements.
Bug fixes
  • Addressed query issues with Kubernetes monitoring + Full-stack Observability
Improvements
  • Data tables have been updated to use the current version from the Strato design system.
  • Wasted energy is now written to the Carbon business event and persisted as energy.measurement.total_wasted. This allows you to report on energy waste for hosts running at less than 100% utilization. The user interface has been updated to report wasted energy metrics (in Optimization recommendations) from the business event, instead of calculating them dynamically. Please review the documentation for more information on the concept of wasted energy: https://docs.dynatrace.com/docs/observe/business-analytics/apps/cost-and-carbon-optimization#get-started--concepts
  • Cost analysis has been updated to detect GCP C4 and C4a machine families.
Bug fixes
  • The early adopter release of Kubernetes monitoring + Full-stack Observability has been updated to support large deployments.
  • Cost analysis has been updated to correct an issue with GCP F1 and G1 machine families. You may see increased costs as a result of this change if you use Dynatrace to monitor hosts using these machine families.
  • A problem with app URLs after filtering has been resolved.
Improvements
  • Intents have been updated to ensure that table filters are persisted correctly into the generated DQL, allowing you to quickly extend app capabilities with custom Notebooks and Dashboards.
Bug fixes
  • Intents now correctly handles custom queries using location filters, allowing you to quickly generate correct DQL on location information.
  • List prices for Google Cloud Platform M1 machine series have been corrected: you may experience an increase in costs if you monitor M1 machine series hosts.
Improvements
  • Carbon support for Dynatrace Kubernetes platform monitoring + Full-Stack observability is now in Early Adopter status and will be available to all customers soon. Customers using Dynatrace Kubernetes platform monitoring + Full-Stack observability can measure energy and carbon emissions of their Kubernetes infrastructure using the Cost & Carbon Optimization app. Business events are generated hourly for Kubernetes clusters and namespaces and can be reported on using custom DQL and dashboards using filters on:
event.type == "carbon.measurement.k8s.namespace" event.type == "carbon.measurement.k8s.cluster" Note: additional information on the Early Adopter program can be found here in the community.
  • Several minor UI changes have been made to align the user experience with recent Dynatrace design library updates.
Bug fixes:
  • Addressed issues with workflow permissions
  • Addressed issue with timestamp of data ingestion
  • Addressed issue with workflow history
Bug Fixes
  • Adds energy calculation for two additional Intel processors. The additional processors have a lower Thermal Dynamic Power (TDP) rating and thread count than the default values. Customers monitoring hosts with these processors may observe a reduction in energy and carbon emissions after this update.
Bug Fixes
  • Corrected issue with workflow permissions
Improvements
  • Better handling of missing GCP API key addition or removal in settings when activating cost data generation
  • Better error message in workflow in case there is a problem in permissions, pointing the user to the resolution path
Bug Fixes
  • The values of energy.measurement.machine are including the energy consumed by memory, network and storage input-output, not only CPU. So that attribute is now completely aligned with Dynatrace Semantic Dictionary definition.
  • The values of energy.measurement.total are adapted to the Dynatrace Semantic Dictionary definition, including the increase factor of the Power Usage Effectiveness (PUE) from the energy.measurement.machine value. So, it is expected, that once solved this bug, the values of energy.measurement.total will suffer an increase depending in the PUE value of the cloud provider or if the host is in on-premise data center.
  • During the upgrade of the Workflow that generates emissions and cost data in the new version, in case the user doesn't have the right permissions in the app or in workflows, it silently failed to ingest cost data as the workflow is not updated. Now the app shows that there is an error pointing the user to the remediation path in permissions.
  • Some changes in the settings where generating an error while updating the configuration of the application, that now is solved.
  • For users migrating from 0.38.1 to newer 1.x.x versions, but decided to stop the data generation before the update, the landing page to start generating data is not displayed, so the users require activate data generation as usual in Settings page
  • Several minor backend bugs solved
Improvements
  • Rename of the application to become Cost & Carbon Optimization with a new icon
  • Adding support to Google Cloud Platform public price list data ingestion. The data ingestion for GCP requires an API key (check documentation for more details)
  • New public prices list cost is calculated every hour from GCP hosts that are instrumented with OneAgent and GCP extension configured.
  • A new notification feature in Settings that allows alerting by email to the user when a workflows fails
  • A new Test connection button in Settings to validate if GCP API key is valid and outbound connections to the cloud vendors price list repositories are open (check documentation for more details)
  • Added a mechanism in the application to remove any duplicated workflow
Bug Fixes
  • Labels on Y axis and in data in the time line charts are displaying the right values
  • Enhancements in the workflow to avoid issues in large environments, supporting more than 20,000 hosts per tenant
  • Solved some gaps in the demo data
Improvements:
  • Changes in Dynatrace Semantic Dictionary in carbon measurement business events to be more descriptive with information stored
    • “energy.measurement.computing” swaps to “energy.measurement.machine”.
    • “energy.measurement.cooling” swaps to “energy.measurement.infrastructure_overhead”.
  • Instead of using publicly available Google Cloud Platform (GCP) carbon intensity factors, calculation will use regional values for better accuracy and transparency
Bug Fixes:
  • Minor UI fixes.
Bug fixes
  • Solved some issues in the values defined in the new schema in Dynatrace Semantic Dictionary.
  • In case the CPU is detected, so energy.measurement.cpu_unknown is false, the model is populated in system.processor.model
  • Reviewed a DQL query that was having a syntax error due to a change on Grail, that has been adapted with a workaround that now it doesn't fail
  • When starting data ingestion, if the user doesn’t have bizevents:write permission, the error toast that appears points to the problem so user can now solve it.
  • If a user tries to start data ingestion without having hosts instrumented, the app shows an error toast message pointing to the problem and inviting to deploy OneAgent in some hosts to start collecting infrastructure metrics that will allow calculating carbon emissions and energy consumptions. Once there are hosts instrumented, user can retry again data generation in Settings.
Bug fixes:
  • Solved an issue that reported an error, but not specified it was due to lack of permissions in Workflows app.
  • Current message is clear of the permissions missing.
  • Minor appearance errors on Settings selectors while preloading the available fields
  • Upgrade in the design system that solves a problem in the timeframe selector in date range
Enhancements
  • Changes to name attributes of a carbon information events generated by the application that is aligned with new version of Dynatrace Semantic Dictionary published on documentation documentation.
  • Application supports old and new schema, but any dashboard or notebook should be adapted to the new schema to work. Major changes that can affect them are:
    • The type of the event is changed from carbon.report to carbon.measurement
    • Attribute emissions is changed to carbon.emissions
    • Attribute totalElectricConsumption changes to energy.measurement.computing
  • In order to support in a dashboard old and new schema with an emissions summarization, it is recommended to introduce this line of DQL code just before that summarisation step
    | fieldsAdd emissions=if(isNotNull(emissions), emissions, else:carbon.emissions)
  • The new schema enriches the calculation data for better transparency and audit-ability.
Enhancements:
  • More readable error messages instead of JSON dump
  • Minor changes related to updates on dependencies
Bug fix
  • Solved a minor UI problem with single value tiles position
  • When a business KPI is defined only without an specific numerical attribute and a count of events is used to display the KPI, it was divided by 1000 due a collateral effect, and now it is showing real values again
Bug fixes
  • Solved a problem related to the toggle to activate data generation in Settings that showed that it was not active, when it was, and re-activating was creating an additional workflow.
Enhancements
  • Updated country carbon intensity values, expanding it to non EU members with their average value
Bug fix
  • Minor changes in querying engine that generated unexpected errors when it was known beforehand that the result was going to be an empty result
Enhancements
Bug fix
Bugfix
  • Solved an issue related to memory usage metrics that were incorrectly captured and they were generating wrong energy consumption estimations
Enhancements
  • Added more robustness to the data ingestion including better handling of batches and introducing retries that can start when ingestion ended
  • Updated the logic when calculating the previous timeframe for comparison in charts to be more accurate
Bug fix
  • Sometimes the amount of hosts identified idling or scaling did not equal to the amount of hosts actually idling/scaling on the Hosts page
  • Changed the behaviour in settings to not allow an equal value in memory threshold between idling and sizing optimizations. Current logic is that memory threshold in idling optimization should be less than memory threshold in sizing optimization
Enhancements
Bug fix
  • Workflows are only updated when a new version is available and not on every run
  • Some minor corrections to avoid confusing warnings on logs
Enhancements
  • Missing permissions on workflow creation and run are better informed, with more details when possible
Bug fix
  • Application will ignore bizevents with empty event.provider or empty event.type (or both at same time) when searching for bizevents that will define key performance indicator
Enhancements
  • New help menu button on top right to provide easy access to documentation and app installed version
  • Removed the update available banner as apps will be upgraded automaticaly
  • More flexibility while defining units on optimization configuration inside settings
Bug fix
  • Solved an issue that allows creating multiple data generation workflows
  • The application won't crash when selecting business event for key performance indicator in case there are event.providers that are empty
Enhancements
  • Hosts list are now exportable to CSV with filters applied
  • Included in the app all Thermal Design Power values from CPUs publicly available used for energy calculations
  • New icon in the app
Enhancements
  • Enhanced demo data in the application without running data generation.
Bug fix
  • Adjustments in single value tiles auto-sizing
Enhancements
  • Updated carbon intensity values from GCP data centers including more regions
Bug fix
  • GCP CPUs detected by OneAgent are appropriately classified for more precise values in energy consumption
Enhancements
  • When starting data ingestion, user doesn't have to wait for the next hour to get first data points, as first data points are generated when activated with the previous hour time frame.
Bug fix
  • Better error messaging when an infrastructure metric in a host is not found and energy/emissions calculations can't happen
  • Resolved a problem where activation of data generation window appears, although there is a workflow active generating data in certain edge scenarios
Bug fix
  • Resolved an issue that denied access to app to viewer users that doesn't require workflow permissions but app was requiring them
Enhancements
  • Current DQL queries in main dashboard and hosts uses all information from bizevent as data center (location attribute)
  • Various minor security enhancements, and update of common libraries
Bug fix
  • More verbose error handling when a DQL query that asks for an infrastructure metric for a host and that query fails providing which metric and which host failed
  • Resolved a problem where activation of data generation window appears, although there is a workflow active generating data in certain edge scenarios.
Bug fix
  • Resolved an issue in an underestimated calculation of energy and emissions in unknown CPU architectures on on-premise hosts that were calculated as if they were in a shared space as cloud providers
Bug fix
  • Don't use the available disk space for calculating carbon emissions in case the host is reporting implausible values for disk space
Enhancements
  • Enhanced queries in hourly data generation allows decreasing Grail load keeping performance
Bug fix
  • In case a property is missing in the settings, application will use the default values.
  • Don't check for certain privileges that are not required
  • A new alert is raised informing that user misses a permission to review the Hub catalog for updates in the app
  • New workflows for data generation are randomly distributed within the hour where data is going to be calculated to avoid loads at same hour
Enhancements
  • A new banner informs that carbon emissions data is in the process of being generated after starting the data generation process during the next 60 minutes
  • In data generation automation, it has been introduced exponential backoff mechanism for Grail queries; queries are retried upon failure a limited number of times with rising pause times before completely failing
  • Minor enhancements in data generation automation
Bug fix
  • Solved some errors in calculation of the disk size and network bandwidth usage that may derive in wrong energy estimations in the storage/network side
  • Reviewed some values for carbon intensity factors for some countries as they weren't accurate
  • Adjustments in energy consumption calculation of cloud hosts for a better precision
  • Solved a problem when opening the app that flickered a modal window
  • Update of the design system to solve some minor bugs in user interface
Bug fixes
  • Fixed a change in hub services that prevented the app to get list of published versions to check if an update is available.
  • Removed a mechanism that blocked the UI in case a query against Grail takes too long. Usually when fetching data from a massive amount of instrumented hosts.
Enhancements
  • Minor enhancements in settings metadata storage
  • Minor enhancements to query performances while extracting data from Grail to build the charts in the app
Enhancements
  • Added new confirmation window at starting or stopping data generation
  • Carbon calculations were enhanced to avoid failures and decrease data leakage in some scenarios
  • Updated some visual components of design system
Bug fix
  • Solved a repeated reloading effect in dashboard when any value in optimization parameters settings are not defined or default values are removed
Enhancements
  • A new field has been added in carbon report business event with the location of the data center where the host is located
Bug fix
  • Fixed bug where missing metrics lead to failing ingest
  • Solved an issue where missing metrics lead to the stop of data processing
Enhancements
  • CO2eq values are shown always with kg units
  • Updated list of data centers from hyperscalers
  • Application shows a banner alerting in case there is a new version available of the app in Hub ready for updating
Bug fixes
  • Filters for the data centers and hosts table now work correctly
  • Minor language adjustments for consistency between apps
  • Solved a collateral effect when business KPI is not defined and widgets on the dashboard are reloading repeatedly
Bug fix
  • Solved a repeated reloading effect in dashboard when any value in optimization parameters settings are not defined or default values are removed.
  • Solved problem with missing metrics that leads to failing ingest
Enhancements
  • Some language enhancements
  • Default timeframe is last 3 days instead of one month
Bug fixes
  • In hosts view, the data center filter shows sorted values of data centers for easier search and select
  • Less generic error messages in different scenarios to guide users to the problem they are having
  • Removed limitation on the number of hosts displayed in the app when there are more than 1000 hosts
  • Display missing values in line chart from energy consumed in main page
Bug fixes
  • Solved a null pointer exception in the carbon calculation
Bug fixes
  • Changed hostId attribute to dt.entity.host in bizevents generated to be compliant with Dynatrace Semantic Dictionary
  • Solved precision discrepancies on energy estimations with physical measurements performed in an edge use case (double socket CPU)
  • Enhancements in error messaging when errors are not caused by the app but to something related to Grail
Maintenance
  • Some enhancements to maintain compatibility with newer components in Appengine
Bug fixes
  • Remediated an issue that blocked data generation activation toggle
  • Guided messaging in errors in starting data generation to help troubleshoot issues that are not related to the app but to Grail misconfiguration (not instrumented hosts, missing infrastructure metrics on Grail required for calculations)
Bug fixes
  • Removed the limit of 1000 hosts in data ingests.
  • Resolved an issue to alert when ingest fails in workflows due to missing user permissions.
  • Added notification that workflow creation failed when the user doesn't have permissions on workflows.
  • The right energy unit scales in the data centers table view.
  • The timeframe selector value is applied to the first change made by the user.
  • If a dashboard tile fails, it doesn't re-trigger all queries on the dashboard.
  • Fixed some minor bugs in ingest workflows and charts.
First production release of Carbon Impact app by Dynatrace including following main functionalities.
Energy consumption and carbon emissions data generation:
  • Automation deployed that calculates every hour energy consumption and carbon emissions for each host
  • Cooling is included in energy consumption
  • Carbon emissions are calculated based on geolocation for AWS data centers, other geolocations are estimated on global average emissions
In app analysis screens:
  • Carbon Impact dashboard that contains total amount of emissions (CO2e grams) in the timeframe, previous timeframe and variation, by datacenter and two charts with energy and carbon emissions cumulated and over time against a defined key performance indicator. Additionally, some optimization suggestions for idling and over-sized instances
  • Instance view that can be filtered by datacenter and optimization options
No release notes
Dynatrace Hub
All (882)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
