Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Dynatrace AssistDynatrace Assist
Dynatrace Assist
Dynatrace Assist
App
Free trialDocumentation
Get started quickly and easily by asking Dynatrace Assist a question. Try out one of the examples to see what's possible.Ask Dynatrace Assist to summarize all open problems to get a quick overview of your environment.Ask Dynatrace Assist to explain your logs to quickly get the insights, potential impact, likely causes and recommended next steps.Get help with identifying and fixing vulnerabilities, such as SQL injections.
  • Product information
  • Release notes
Overview
Dynatrace Assist is your natural‑language gateway into Dynatrace Intelligence, the agentic operations system that brings the full platform together for you. Instead of switching between dashboards, queries, apps, and other tools, you simply ask a question and Dynatrace Intelligence responds accordingly, using Dynatrace’s generative, causal, and predictive AI capabilities as well as all agentic tools provided by Dynatrace MCP Server. Like a true team member, Assist draws context from Grail, maps relationships through Smartscape, and collaborates with Dynatrace agents to deliver grounded, precise answers. As the conversation continues, you naturally move from insights and understanding to exploration and action. Ask. Analyze. Act.
Use cases
Use Assist for use cases such as:
  • In-context assistance to help with onboarding, Dynatrace usage, and configuration topics
  • Explain Kubernetes warning signals, Logs, Problems, threat detection findings, or database insights integrated right into the respective app
  • Analyze your data, get insights, and recommend next steps right within the Assist chat interface
  • Interact with available Dynatrace foundational agents for deeper analysis when needed
and much more coming in the next weeks and months.
Get started
To get started with this app, you simply need to enable generative AI functionality for your environment and assign the necessary permissions to the relevant user groups via a policy. See our documentation for further details.
Once users have access, all they need to do to get started is to select the new Assist entry (below the global search) in the dock and ask Dynatrace Assist their desired question, or select one of the example prompts.
Curious to understand how Dynatrace Intelligence generative AI is being adopted across your environment? Check out the read-made dashboard called “Generative AI feature adoption”.
*Please note that your prompts are sent to LLMs hosted by enterprise vendors such as Microsoft Azure AI and AWS Bedrock, which power Dynatrace Intelligence generative AI. These vendors don't store the submitted data or any responses. The prompts and related responses are used only to serve your experience. Neither our enterprise vendors nor Dynatrace use the prompts to fine-tune or improve any models or services, or to train models across customers or environments.
Dynatrace may store prompts submitted to Dynatrace Assist and the responses provided by the LLMs to better understand use cases, contextualize feedback on those responses, and identify additional user expectations.*
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Dynatrace Assist
Dynatrace MCP Server logo
MCP Server Tools logo
MCP Server Tools
Enable your agents with reliable insights, with our toolkit accessible via MCP.
Dynatrace Intelligence for Workflows logo
Automate smarter with intelligent detection, forecasting, and custom analysis.
Dynatrace Intelligence logo
Action based on answers with deterministic insights and agentic operations.
Agentic Workflows logo
Agentic Workflows
Build agentic workflows to automate, orchestrate and govern operations at scale.
More resources
Ask, analyze, and act with Dynatrace Intelligence
Your agentic partner that helps you gather insights
Read more
Full version history
ReleaseDate
1.336.0
Minor Changes
  • You can now send feedback when Assist returns an error message.
  • Minor improvements and bugfixes.
1.335.1
Minor Changes
1.334.1
Minor Changes
1.333.0
Minor Changes
  • Minor changes and improvements.
1.332.0
Dynatrace Assist now supports agentic capabilities, which let you ask questions and analyze issues from a single conversational interface powered by Dynatrace Intelligence. It combines generative, causal, and predictive AI with environment context (Grail and Smartscape) to deliver transparent, data‑backed recommendations and end‑to‑end remediation guidance.
Highlights
  • Conversational, agentic flows: Multi‑step reasoning guides you from question, to insight, to actionable steps without switching context.
  • Deep environment awareness: pulls context from Grail and Smartscape for environment‑specific analysis.
  • Transparent recommendations: shows the data that backs each suggestion so teams can validate and trust actions.
  • Explain raw signals: select a log or signal and get expert‑style explanations of impact, likely causes, and recommended next steps.
  • Integration of Dynatrace MCP Server: leverages agentic tooling to access production insights and trigger deeper analyses when needed.
Read more about the release here, or learn more about how to get started with Agentic mode.
1.331.2
Minor Changes
  • Correctly reset feedback button when switching between conversations
1.330.3
With the launch of Dynatrace Intelligence, the Ask Davis CoPilot app has been renamed to Dynatrace Assist. You'll also see refreshed icons across the interface for clearer, more consistent visuals.
1.328.1
Minor Changes
  • Updated the background color scheme in Davis CoPilot chat to improve message distinction and readability. This makes it easier to identify different messages in the chat interface in order to better follow conversation flows.
  • Improved error message handling to better understand what went wrong.
1.327.0
Minor Changes
1.326.0
Minor Changes
  • Introducing the new Davis CoPilot Feature Adoption Dashboard, designed to give administrators a comprehensive view of how generative AI features are being utilized across their environment. With this dashboard, you can:
    • Track key adoption metrics to monitor Davis CoPilot feature usage and engagement.
    • Gain user behavior insights to understand where assistance is needed.
    • Identify guardrail interactions, highlighting areas where users encounter limits.
    • Monitor for potential misuse or abuse of generative AI capabilities.
  • Minor fixes and improvements.
1.324.1
Minor Changes
1.323.0
Minor Changes
1.322.0
Minor Changes
  • Increased context limits so that CoPilot can give even more precise answers
1.321.0
1.320.0
  • Added some new prompt examples, so you can explore more use cases.
1.319.1
  • Improved conversation overview list:
    • Conversations can now be sorted by name and last modified date
    • Columns can be resized so you can see more information upfront
  • Improved auto-focus behaviour so you can get to typing your prompts quicker
  • Improved the streaming, to prevent interrupted responses.
1.318.1
  • Fixed a bug that prevented you from updating or interacting with older conversations
  • Minor UI improvements
1.317.0
1.316.0
1.315.0
1.314.0
1.313.2
Bug Fixes
  • Fixed copilot conversations created by an intent not using the correct conversation history
1.313.1
Bug Fixes
  • Fixed copilot response not being sent in the feedback event
1.313.0
Minor Changes
  • Introduced bulk delete action on conversation overview list.
  • Conversation overview list now has no limit on how many conversations can be shown.
  • Minor improvements.
1.312.0
Minor Changes
  • Improved response streaming behaviour
1.311.0
Minor Changes
  • Minor text improvements.
1.310.0
Minor Changes
  • User input now supports markdown formatting.
  • You can now explain problems directly from a Problem detail screen
  • You can now ask Davis CoPilot to summarize a database execution plan
  • Minor performance improvements and fixes
1.308.0
  • Conversation list view now shows up to 1000 past conversations and includes pagination
  • Minor text changes
1.307.1
Availability changes
  • With this release, Davis CoPilot Chat is generally available for all customers.
Minor changes
  • Increased the prompt character limit from 3000 to 5000
  • Increases number of conversations shown in list view from 50 to 200
  • Filtering in the conversations list view is now case insensitive
  • Improved error messages
Dynatrace Hub
All (897)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility.
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Streamline incident management with automated Pageruty workflows.
Cursor IDE logo
Cursor IDE
Boost developer productivity and get real-time, code-level insights into Cursor.
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
