Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Security Posture ManagementSecurity Posture Management
App
Free trialDocumentation
The Overview page shows a high-level information about the security compliance state in your environment.The Assessment results page provides a compliance view of all evaluated rules from the supported security standards. Filters allow quick selectionAssessed resources from your environment are marked as 'Passed' when no misconfigurations are discovered in the context of a given rule.Assessed resources from your environment are marked as 'Failed' when misconfigurations are discovered in the context of a given rule.
  • Product information
  • Release notes
Overview
Security Posture Management is a platform experience for detecting, visualizing, analyzing, and remediating security posture and compliance findings, including misconfigurations and regulatory compliance assessments.
Use cases
  • Security hardening: Prioritize and report on the most critical misconfigurations to enhance security.
  • Compliance reporting: Filter and sort compliance findings to generate detailed reports on compliance successes and failures.
  • Remediation prioritization: Create a prioritized list of compliance and security posture findings for remediation teams to address efficiently.
Get started
To get started with Security Posture Management, see the documentation.
Details
What you can achieve
  • Regulatory compliance assessments: Evaluate your environment against regulatory requirements and security best practices.
  • Compliance insights: Gain a clear overview of compliance coverage across your environment.
  • Prioritized findings: Search, filter, and prioritize findings to address the most critical issues first.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Full version history
ReleaseDate
1.9.1
Patch Changes
  • Fixed error logging when opening the rule details panel.
1.9.0
Minor Changes
  • Removed the requirement related to security problems permissions for easier access to the Security Posture Management app.
Patch Changes
  • Abbreviated large numbers across the app to improve overall readability.
  • Cleaned up migration information related to security.events on the 'Security Posture overview' ready-made dashboard.
1.8.3
Patch Changes
  • Improved handling of exceeded response size limits in the "Assessed resources" section of the rule details panel.
  • Improved clarity of the permissions requirements for using the SPM app.
  • Enhanced readability of result details by wrapping long header content when space is limited.
  • Aligned SPM Settings widget layout.
1.8.0
Minor Changes
  • Introduced management of security compliance standards. The configuration is now available under Settings > Analyze and alert > Application Security > Security Posture Management.
  • Optimized data loading to display compliance results faster.
Patch Changes
  • Improved error and permission handling in the "What's new" modal.
1.8.0
Minor Changes
Patch Changes
1.7.0
Minor Changes
  • Introduced the "Explain assessment" button in the rule details panel. Backed by Davis CoPilot, it adds richer context around each rule and its outcome, and automatically suggests targeted remediation steps for any failed assessments.
Patch Changes
  • Improved the empty state of the rule details panel.
  • Made rule details panel viewable even when the specific rule is not shown in the table.
  • Added preservation of filter settings in the rule details panel when switching tabs.
1.6.1
Minor Changes
  • Added views in the "Assessment results" page: Recommended (default) and Complete. Use Recommended to focus on the most relevant findings for your environment.
  • Enhanced the "Assessment results" table with the full security standard name, allowing filtering and sorting to focus on a specific standard when needed.
  • Added an intent button for known resource types in the "Assessed resources" section of the rule details panel.
  • Added a "Recommended documents" section to the "Overview" page with a link to the distributed, ready-made dashboard.
  • Improved guidance on the "Missing permissions" and the "Missing license" pages.
Dynatrace Hub
All (897)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility.
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Streamline incident management with automated Pageruty workflows.
Cursor IDE logo
Cursor IDE
Boost developer productivity and get real-time, code-level insights into Cursor.
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
