Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
PowerConnect for SAP on DynatracePowerConnect for SAP on Dynatrace
SAP S/4HANA observability with PowerConnect. On RISE, on-prem, BTP - all-in-one
Technology by SoftwareOne
Documentation
PowerConnect dashboard examplePowerConnect dashboards libraryPowerConnect data ingest settings
  • Product information
Overview
Start SAP performance management in Dynatrace, in minutes, and achieve great results leveraging rich library of the use case-oriented dashboards.
Running S/4HANA, ECC, PI/PO, BO, BW?
  • PowerConnect is what you need for operational monitoring.
Using SAP SaaS like Ariba, SalesCloud, SuccessFactors? Relying on SAP CPI or CIS?
  • PowerConnect delivers observability of those cloud apps too.
Modernizing your landscape with SAP RISE, adopting BTP?
  • PowerConnect is certified on more than a dozen SAP platforms.
Broaden your view to the SAP operations using Business Flows monitoring. Deepen the diagnostics of the SAP issues using Services app-powered insights into the Open Telemetry traces collected on monitored SAP systems.
How it works
PowerConnect by SoftwareOne provides the data gathered from SAP systems where it's installed. Dynatrace analyzes and visualizes this data, and delivers answers to your questions on SAP performance, usage, availability and business process health.
PowerConnect application for Dynatrace has been designed to set up the Dynatrace Platform integration in a few easy steps. Get the app by requesting it from PowerConnect, deploy it on your Dynatrace tenant and let it prepare all the necessary settings for you.
Note to Dynatrace Managed customers: we have a Dynatrace extension for you, since Managed can't run apps. Learn more below in this document.
Use cases
Onboarding and configuration of the PowerConnect integration with Dynatrace:
  • Set up recommended Grail buckets for secure storage of different categories of the SAP observability data
  • Set up recommended OpenPipeline settings for efficient processing of the PowerConnect signals
  • Install required PowerConnect dashboards from the library of 200+ dashboards provided with the application, manage dashboard upgrades and removals when required
  • Verify operational status of the data reception as it is ingested by PowerConnect running on your SAP systems
Once onboarding is completed, use Dashboards, Services and Business Flows apps to:
  • Access dashboards designed for operational monitoring of your SAP landscape
  • Get security insights, including user behavior analytics, access monitoring, threat correlation
  • Enable SAP business services observability, including process monitoring and data validation
  • Troubleshot SAP services with trace-level insights into SAP runtime activities
Get started
PowerConnect application is designed to help you set up PowerConnect integration with Dynatrace. This application relies on data fed into Dynatrace by the PowerConnect agent deployed on your SAP systems.
  • To start, enable PowerConnect on all your SAP systems. Follow instructions available in PowerConnect documentation
  • Download the application artifact from the link provided to you by your SoftwareOne representative
  • Add application to your Dynatrace tenant using the Hub app (Hub > Manage > Upload app),
  • Then open the application and follow onscreen guidance to let the app set up buckets, OpenPipeline settings and dashboards for you
    • In the first step, you will be asked to add an OAuth client details. Create an OAuth client in Account Management > Identity & access management > OAuth clients
    • Note: verify whether https://sso.dynatrace.com is on the list on Allowlist in Settings Classic > Settings > Preferences > Limit outbound connections.
Details
Once PowerConnect is set up and feeding Dynatrace, its data will land in the buckets that the app set up for you. OpenPipeline rules, set up by the app, assure that.
  • Dashboards provided by this app will be populated with data from your SAP systems. You can copy the dashboards and modify them to your needs, or create your own. PowerConnect data, which characterizes your SAP systems operations, is available for you as metrics, logs, traces and business events, like any other observability signals that Dynatrace maintains.
  • Services app can be used to analyze traces collected from your SAP systems by the PowerConnect agent. Mind that SAP traces may get long, as SAP operations may be comprised of dozens or hundreds of steps (i.e. spans) that together orchestrate SAP transactions or tasks.
  • Business Flow app lets you organize events monitored by PowerConnect on your SAP systems into the flows that reflect business processes implemented on your system, including specifics of your SAP implementation. Then observe success rate and diagnose anomalies and failures automatically, with troubleshooting data linking down to metrics, logs and traces collected as your business flow has been executing.
Note on license consumption This application by itself does not incur any Dynatrace license consumption, as it is responsible for system set up and configuration for seamless PowerConnect experience. Subscription consumption level incurred by PowerConnect data ingest heavily depends on the monitored SAP systems size and activity. You will store monitored SAP system telemetry data as logs, metric, biz events and traces in Dynatrace, for the time period you define, typically between 90 and 360+ days.
Logs will be translated to essential metrics, for easy reporting purposes, but more advanced reporting may still require DQL queries.
Past experience tells us that you can expect:
Between 5 GB and 500 GB logs ingested by PowerConnect, per day
Check your rating card for costs that such log ingestion will incur on your tenant. See documentation for examples of the consumption calculation approaches and online reporting.
Note on license requirements PowerConnect is licensed separately from Dynatrace. It is a 3rd-party product governed by an End User License Agreement between you and SoftwareOne.
This application is also provided by SoftwareOne and is a subject to license agreement between you and SoftwareOne.
More on PowerConnect See PowerConnect Compatibility Matrix for details of the SAP systems supported. Consult PowerConnect documentation for detailed list of metric extractors applied by PowerConnect on SAP systems. For complete details about the value of monitoring SAP with PowerConnect for Dynatrace, see this blog post and PowerConnect pages.
Dynatrace Managed notes
If you are running Dynatrace Managed, we have a Dynatrace extension for you, since Managed can't run apps.
  • Download the extension artifact from the link provided to you by your SoftwareOne representative.
  • Add it to your environment in Manage > Dynatrace Hub > Manage & upload extensions > Upload custom Extension 2.0.
The extension will provision log processing and metric extraction rules on your tenant, so you can benefit from PowerConnect insights. A dashboard and a few Unified Analysis screens offer a starting point into the SAP monitoring overview and status analysis. Sample alert definitions round the package.
Metrics availability limitations Managed tenants (which have no Grail underpinnings) can't deliver several metrics from PowerConnect. Following metrics are not available on Dynatrace Managed:
  • ABAP System: Workprocess Utilization
  • ABAP System: Debug Execution
  • ABAP SQL Server Database: Transactions per Second
  • ABAP SQL Server Database: User Connections
  • ABAP System Fiori: Response Time for Fiori Front End
  • ABAP System Fiori: Max Respone Time
  • ABAP System Fiori: Response time by user (median)
  • ABAP HANA Database: Query Executions by Schema name
  • ABAP HANA Database: Active Statements
Dashboards availability limitations Dynatrace Managed provides a dozen of Unified Analysis screens out of the box, but you need to build dashboards yourself.
Dynatrace SaaS opens access to 200+ ready-made PowerConnect dashboards. Upgrade to Dynatrace SaaS to leverage full potential of PowerConnect on Dynatrace.
SoftwareOne
Documentation
By the partner
Contact SoftwareOneRequest support
Contact salesRequest information
Copy to clipboard
Related to PowerConnect for SAP on Dynatrace
Dashboards logo
Dashboards
Services logo
Services
Maintain centralized control over service health, performance, and resources.
Distributed Tracing logo
Distributed Tracing
Analyze and slice distributed traces by any attribute and from any source.
Business Flow logo
Business Flow
More resources
Simplify SAP Monitoring with PowerConnect and Dynatrace
Read more
Dynatrace Hub
All (814)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityDigital ExperienceBusiness Observability
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Analyze abnormal system behavior and performance problems detected by Davis AI.
Logs logo
Logs
Security Investigator logo
Fast and precise forensics for security and logs on Grail data with DQL queries.
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Davis Anomaly Detection logo
Detect anomalies in timeseries using the Davis AI
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Automate tasks in your IT landscape, remediate problems, and visualize processes
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Overview logo
Security Overview
Get a comprehensive overview of the security of your applications.
Code-Level Vulnerabilities logo
Detect vulnerabilities in your code in real time.
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub CoPilot Coding Agent logo
GitHub Copilot Custom Agent
Observability for Developer on Jetrains logo
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
