Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Oracle WebLogicOracle WebLogic
Oracle WebLogic
Oracle WebLogic
Intelligently monitor, analyze, and optimize your app server and deployed apps.
Technology
Free trial
  • Product information
Overview
Dynatrace automatically detects all applications and microservices deployed in your application server and provides automatic end-to-end tracing, application server metrics and log insights. Dynatrace visualizes your web application and its dependencies from website to application to container, infrastructure and cloud. It diagnoses anomalies in real-time with AI and pinpoints the root-cause down to the broken code before your customers are even affected. Deep code-level insights combined with market-leading profiling capabilities like method hotspots, error/exception analysis, memory profiling, and thread analysis will help you leverage the robustness of your production environment.
Use cases
  • Capture every transaction, across every tier, without gaps or blind spots.
  • Understand all dependencies of your applications including all database statements executed and their performance.
  • Improve the performance of your Java code with continuous insights into your applications.
  • Profile CPU, memory and thread problems with Dynatrace' industry leading production grade continous profiler.
  • Detect availability and performance problems across your stack proactively.
  • Monitor all your application metrics via Dynatrace's builtin JMX monitoring capability.
  • Leverage open observability frameworks like OpenTelemetry or Micrometer to add custom metrics and custom traces instrumentation.
Get started
If your WebLogic is running on a virtual machine directly, install OneAgent on that virtual machine to get started.
If your WebLogic is running as a workload in Kubernetes, set up Dynatrace on Kubernetes.
If your WebLogic is running as a workload in OpenShift, set up Dynatrace on OpenShift.
Activate the JMX extension for WebLogic connection pools to get full metric insight.
Activate log monitoring to get full log insight.
Dynatrace
By Dynatrace
Dynatrace support center
Copy to clipboard
Customer story Sofico
“We’re intrigued by its capability to work almost out of the box as well as being able to monitor system aspects as well as application performance and user experience.”
Sofico logo
Related to Oracle WebLogic
Play Framework logo
Play Framework
Automatically and intelligently monitor, analyze, and optimize your applications developed with Play Framework.
Netty logo
Netty
End-to-end observability for your Netty web framework with code-level insight.
Apache Tomcat logo
Apache Tomcat
Automatically and intelligently monitor, analyze, and optimize your application server and all applications deployed anywhere in your stack.
Red Hat JBoss Enterprise logo
Smartly monitor, analyze, and optimize your app server and stack apps
Azure Spring Apps logo
Azure Spring Apps
Brings modern microservice patterns to Spring Boot apps eliminating boilerplate code to quickly develop robust Java apps.
Akka logo
Akka
Smartly monitor, analyze, and optimize Akka applications automatically.
Dynatrace Hub
All (812)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityDigital ExperienceBusiness Observability
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Analyze abnormal system behavior and performance problems detected by Davis AI.
Logs logo
Logs
Security Investigator logo
Fast and precise forensics for security and logs on Grail data with DQL queries.
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Davis Anomaly Detection logo
Detect anomalies in timeseries using the Davis AI
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Automate tasks in your IT landscape, remediate problems, and visualize processes
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Overview logo
Security Overview
Get a comprehensive overview of the security of your applications.
Code-Level Vulnerabilities logo
Detect vulnerabilities in your code in real time.
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Observability for Developer on Jetbrains logo
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
