Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Oracle Autonomous Database on OCIOracle Autonomous Database on OCI
Monitor health and performance of the Oracle Autonomous Database.
Extension
Free trialDocumentation
Oracle Autonomous Database on Oracle Cloud Infrastructure - a sample dashboardOracle Autonomous Database on Oracle Cloud Infrastructure - a Unified Analysis screen
  • Product information
  • Release notes
Overview
This extension monitors basics of the Oracle Autonomous Database, providing server-side observability on the database engine availability and performance level. This extension provides a light alternative to the Oracle Database monitoring extension that is compatible with OCI Autonomous DB.
Use cases
  • Monitor availability of the Autonomous DB and the underlying Oracle Cloud Infrastructure health.
  • Track usage of the database storage and network resources.
  • Track database usage in terms of users, logins, sessions, number of queries executed.
  • Understand the resource impact that your applications have on the Autonomous DB, including wait times.
  • Understand the impact that databse-side resource shortages have on your application.
Compatibility information
  • OCI API access from ActiveGate is required
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Extension content
Content typeNumber of items included
metric metadata
40
alerts
3
alert template
3
screen layout
2
generic relationship
1
document dashboard
1
dashboards
1
list screen layout
1
generic type
2
screen entities lists
1
screen chart groups
8
Feature sets
CPU Utilizationcloud.oci.database.autonomous.cpu_utilCPU utilization aggregated across all consumer groups.Percent
Storage Utilizationcloud.oci.database.autonomous.storage_utilPercentage of provisioned storage capacity currently in use.Percent
Maximum Storage Spacecloud.oci.database.autonomous.max_storage_spaceMaximum amount of storage reserved for the database.GigaByte
Storage Space Allocatedcloud.oci.database.autonomous.storage_space_allocatedSpace allocated to the database.GigaByte
Storage Space Usedcloud.oci.database.autonomous.storage_space_usedSpace used by the database.GigaByte
DB Timecloud.oci.database.autonomous.db_timeRate of accumulation of database time (CPU + Wait) by foreground sessions.Second
Wait Timecloud.oci.database.autonomous.wait_timeAverage rate of accumulation of non-idle wait time by foreground sessions.Second
CPU Timecloud.oci.database.autonomous.cpu_timeRate of accumulation of CPU time by foreground sessions.Second
Database Availabilitycloud.oci.database.autonomous.database_availabilityDatabase availability for connections (1 = DB Available, 0 = DB Unavailable).Count
Connection Latencycloud.oci.database.autonomous.connection_latencyTime taken to connect to a ADB-S database in each region from a VM in the same region.MilliSecond
Query Latencycloud.oci.database.autonomous.query_latencyTime taken to display results of a simple query.MilliSecond
Session Logical Readscloud.oci.database.autonomous.session_logical_readsSum of "db block gets" plus "consistent gets".Count
DB Block Changescloud.oci.database.autonomous.db_block_changesNumber of changes that where part of an update or delete operation to all blocks in SGA.Count
Physical Readscloud.oci.database.autonomous.physical_readsNumber of data blocks read from disk.Count
Physical Writescloud.oci.database.autonomous.physical_writesNumber of data blocks written to disk.Count
Physical Read Total Bytescloud.oci.database.autonomous.physical_read_bytesSize in bytes of disk reads by all database instance activity.Count
Physical Write Total Bytescloud.oci.database.autonomous.physical_write_bytesSize in bytes of disk writes by all database instance activity.Count
Sessionscloud.oci.database.autonomous.sessionsNumber of sessions in the database.Count
Execute Countcloud.oci.database.autonomous.executesNumber of user and recursive calls that executed SQL statements.Count
Running Statementscloud.oci.database.autonomous.running_statementsNumber of running SQL statements aggregated accross all consumer groups.Count
Queued Statementscloud.oci.database.autonomous.queued_statementsNumber of queued SQL statements aggregated accross all consumer groups.Count
Transaction Countcloud.oci.database.autonomous.transactionsCombined number of user commits and user rollbacks.Count
Current Logonscloud.oci.database.autonomous.current_logonsNumber of successful logons.Count
User Callscloud.oci.database.autonomous.user_callsCombined number of logons, parses, and execute calls.Count
Total Parse Countcloud.oci.database.autonomous.parsesNumber of hard and soft parses.Count
Failed Logonscloud.oci.database.autonomous.failed_logonsNumber of logons that failed due to an invalid username and/or password.Count
Failed Connectionscloud.oci.database.autonomous.failed_connectionsNumber of failed database connections.Count
User Commitscloud.oci.database.autonomous.user_commitsNumber of user commits.Count
User Rollbackscloud.oci.database.autonomous.user_rollbacksNumber of times users manually issue the ROLLBACK statement or an error occurs during user's transactions.Count
Redo Sizecloud.oci.database.autonomous.redo_sizeAmount of redo generated in bytes.Count
Hard Parse Countcloud.oci.database.autonomous.hard_parsesNumber of parse calls (real parses).Count
Failures Parse Countcloud.oci.database.autonomous.failed_parsesNumber of parse failures.Count
Bytes Received via SQL*Net from DBLinkcloud.oci.database.autonomous.sql_net_bytes_from_dblinkNumber of bytes received from a database link over Oracle Net Services.Count
Bytes Sent via SQL*Net to DBLinkcloud.oci.database.autonomous.sql_net_bytes_to_dblinkNumber of bytes sent over a database link over Oracle Net Services.Count
Bytes Received via SQL*Net from Clientcloud.oci.database.autonomous.sql_net_bytes_from_clientNumber of bytes received from the client over Oracle Net Services.Count
Bytes Sent via SQL*Net to Clientcloud.oci.database.autonomous.sql_net_bytes_to_clientNumber of bytes sent to the client from the foreground processes.Count
APEX Page Eventscloud.oci.database.autonomous.apex_page_eventsNumber of APEX page events.Count
APEX Page Load Timecloud.oci.database.autonomous.apex_page_load_timeAverage APEX page execution time.Second
Active APEX Applicationscloud.oci.database.autonomous.apex_active_applicationsNumber of APEX applications with activity.Count
APEX Workspace Countcloud.oci.database.autonomous.apex_workspacesTotal number of user-created workspaces.Count
Related to Oracle Autonomous Database on OCI
Oracle Database logo
Oracle Database
Observe, analyze and optimize the usage, health and performance of your database
Oracle Cloud Infrastructure (OCI) logo
Monitor health and performance of the Oracle Cloud Infrastructure.
Full version history
ReleaseDate
⚠️ Important Change
  • This release requires a Minimum Dynatrace Version version of 1.318.0 or higher.
New in this version
  • Added ALERT_TEMPLATES for anomaly detectors in the Davis Anomaly Detection app (latest Dynatrace only).
Patch level changes
  • Improvements to avoid hitting OCI API rate limit wherever possible.
⚠️IMPORTANT CHANGE: This extension release requires Dynatrace cluster version 1.313 or later.
New features:
  • The dt.security_context attribute is now propagated to all entities created by the extension. When enabling entity access control based on dt.security_context ensure you set the Grail security context destination property to dt.security_context
  • Enabled the extension to present the Dynatrace Platform (a.k.a. Gen3) entity details screens in the future platform apps that will expect these screens
Patch level changes:
  • Oracle SDK currency updates
New features:
  • Added possibility of an explicit proxy configuration for the API connection. Note that OCI SDK may still use OS-level environment proxy setting. See Q&A for more information on proxy support.
  • Updated support for Oracle Cloud sovereign regions, to include recently rolled out new regions.
Patch level changes
  • Resiliency improvements to handle minor API response inconsistencies
  • Minor bug fixes
Initial release of the Oracle Autonomous Database on Oracle Cloud Infrastructure monitoring extension.
Dynatrace Hub
All (812)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityDigital ExperienceBusiness Observability
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Analyze abnormal system behavior and performance problems detected by Davis AI.
Logs logo
Logs
Security Investigator logo
Fast and precise forensics for security and logs on Grail data with DQL queries.
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Davis Anomaly Detection logo
Detect anomalies in timeseries using the Davis AI
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Automate tasks in your IT landscape, remediate problems, and visualize processes
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Overview logo
Security Overview
Get a comprehensive overview of the security of your applications.
Code-Level Vulnerabilities logo
Detect vulnerabilities in your code in real time.
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Observability for Developer on Jetbrains logo
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
