Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
OpenInferenceOpenInference
OpenInference
OpenInference
Instrument your AI agents, services and apps with OpenInference.
Technology
Free trialDocumentation
Get visibility into Agent Topology and dependency for your OpenInference instrumented AI servicesOpenInference reference instrumentation architecturePrompts stream showing all Agent and LLM interactions with model version, token count, and full prompt/response content.Trace-level debug view showing agentic span hierarchy, tool calls, prompt and response content, and agent topology for a single AI agent run.OpenPipeline dynamic routing rules directing Langfuse, OpenLIT, and OpenInference spans to dedicated attribute-normalization pipelines.Capture full message history with roles, content, and tool calls via Bindplane's genainormalizer processor.
  • Product information
Overview
OpenInference is an open observability standard for AI applications, developed by Arize AI and built on top of OpenTelemetry. It provides auto-instrumentation for 33+ frameworks: including LangChain, LlamaIndex, CrewAI, AutoGen, OpenAI, Anthropic, and more. Capturing LLM calls, agent runs, tool invocations, retrieval steps, and quality evaluations as distributed traces, with no changes required to your application code.
OpenInference uses its own semantic conventions (llm.model_name, llm.token_count.*, openinference.span.kind, and others). Set OPENINFERENCE_ENABLE_GENAI_SEMCONV=true and OpenInference also emits the gen_ai.* OpenTelemetry attributes, so your data populates the AI Observability app out of the box.
By connecting OpenInference to Dynatrace, you get full-stack visibility into your AI workloads: model performance, token consumption, cost, tool behavior, retrieval quality, and evaluation scores, all in one place.
Use cases
Monitor AI service health and performance
  • Detect bottlenecks by tracking real-time metrics including request counts, durations, and error rates across LLM providers and models.
  • Manage costs with automated token-level cost calculations broken down by model and provider.
  • Set error budgets for performance and cost controls, and validate consumption and response time per model.
End-to-end tracing and debugging of agentic AI
  • Achieve full visibility of prompt flows, tool calls, retrieval steps, and model handoffs — from initial request to final response — for faster root cause analysis.
  • Capture detailed debug data, including full prompt and completion content, to troubleshoot issues in complex multi-agent pipelines.
  • Pinpoint exact failure points in tool calls, prompts, tokens, or system integrations with granular span-level tracing following the GenAI semantic conventions.
Evaluate AI quality in production
  • Run LLM-as-judge and custom evaluation with dt-evals as first-class spans alongside your inference traces, with scores, labels, and explanations attached to the evaluated response.
  • Track quality metrics — relevance, groundedness, toxicity, and custom evaluators — over time alongside latency and cost.
  • Correlate evaluation regressions with model version changes, prompt updates, or provider switches.
Multi-framework coverage with a single pipeline
  • Instrument 33+ AI frameworks with a single OTLP export pipeline, no per-framework Dynatrace integration required.
  • Emit gen_ai.* attributes natively with OPENINFERENCE_ENABLE_GENAI_SEMCONV=true and get a consistent view in the AI Observability app, whichever framework your team uses.
  • Extend coverage to retrieval (RAG), reranking, and guardrail spans beyond standard LLM calls.
Get started
Send traces from your OpenInference-instrumented application to Dynatrace and analyze them in the AI Observability app. Set OPENINFERENCE_ENABLE_GENAI_SEMCONV=true so the instrumentation emits the gen_ai.* attributes the app uses.
To get started, see the OpenInference examples on GitHub and Get started with OpenInference.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Copy to clipboard
Related to OpenInference
AI Observability logo
AI Observability
Dynatrace Hub
All (958)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
