Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
MySQL (remote monitoring)MySQL (remote monitoring)
Remotely monitor your MySQL instances, collect key KPIs and slow queries details
Extension
Free trialDocumentation
Overview dashboardInstance statistics on the new platformSlow queries viewExecution plan details
  • Product information
  • Release notes
Overview
Remotely monitor MySQL databases where you cannot install an OneAgent.
Compatibility information
  • MySQL >= 8.0
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Extension content
Content typeNumber of items included
screen chart groups
13
screen logs cards
4
screen injections
1
screen layout
3
alerts
1
metric metadata
37
screen entities lists
6
document dashboard
1
list screen layout
2
generic relationship
3
screen custom cards
2
screen actions
2
dashboards
1
screen properties
3
generic type
2
alert template
1
screen dql table
4
Feature sets
Commitsmysql.statements.commit.countThe number of COMMIT statements executed by this serverCount
Deletesmysql.statements.delete.countThe number of DELETE statements executed by this serverCount
Multi-Table Deletesmysql.statements.delete_multi.countThe number of multi-table DELETE statements executed by this serverCount
Insertsmysql.statements.insert.countThe number of INSERT statements executed by this serverCount
Selectsmysql.statements.select.countThe number of SELECT statements executed by this serverCount
Updatesmysql.statements.update.countThe number of UPDATE statements executed by this serverCount
Executesmysql.statements.execute.countThe number of EXECUTE statements executed by this serverCount
Multi-Table Updatesmysql.statements.update_multi.countThe number of multi-table UPDATE statements executed by this serverCount
Bytes Sentmysql.statements.bytes_sent.countThe number of bytes sent to all clientsByte
Bytes Receivedmysql.statements.bytes_received.countThe number of bytes received from all clientsByte
Database Sizemysql.databases.sizeThe size of the DatabaseMegaByte
Queriesmysql.global_status.queries.countThe total number of queries executed by the server. This includes statements executed within stored procedures, unlike the Questions variable.Count
Slow Queriesmysql.global_status.slow_queries.countThe number of queries that have taken more than long_query_time seconds. This counter increments regardless of whether the slow query log is enabled. For information about that log, see Section 5.4.5, The Slow Query Log.Count
Table Locks Waitedmysql.global_status.table_locks_waited.countThe number of times that a request for a table lock could not be granted immediately and a wait was needed. If this is high and you have performance problems, you should first optimize your queries, and then either split your table or tables or use replication.Count
Table Locks Immediatemysql.global_status.table_locks_immediate.countThe number of times that a request for a table lock could be granted immediately.Count
Current Connectionsmysql.global_status.current_connectionsThe number of currently open connections.Count
Threads Runningmysql.global_status.threads_runningThe number of threads that are not sleeping.Count
Innodb Buffer Pool Pages Datamysql.global_status.innodb_buffer_pool_pages_dataThe number of pages in the InnoDB buffer pool containing data. The number includes both dirty and clean pages. When using compressed tables, the reported Innodb_buffer_pool_pages_data value may be larger than Innodb_buffer_pool_pages_totalCount
Innodb Buffer Pool Pages Dirtymysql.global_status.innodb_buffer_pool_pages_dirtyThe current number of dirty pages in the InnoDB buffer pool.Count
Innodb Buffer Pool Pages Freemysql.global_status.innodb_buffer_pool_pages_freeThe number of free pages in the InnoDB buffer pool.Count
Innodb Buffer Pool Pages Totalmysql.global_status.innodb_buffer_pool_pages_totalThe total size of the InnoDB buffer pool, in pages. When using compressed tables, the reported Innodb_buffer_pool_pages_data value may be larger than Innodb_buffer_pool_pages_totalCount
Innodb Data Readsmysql.global_status.innodb_data_reads.countThe total number of data reads (OS file reads).Count
Innodb Data Writesmysql.global_status.innodb_data_writes.countThe total number of data writes.Count
Innodb Data Readmysql.global_status.innodb_data_read.countThe total amount of data read from files.Byte
Innodb Data Writtenmysql.global_status.innodb_data_written.countThe total amount of data written.Byte
Innodb Buffer Pool Readsmysql.global_status.innodb_buffer_pool_readsThe number of logical reads that InnoDB could not satisfy from the buffer pool, and had to read directly from disk.Count
Innodb Buffer Pool Read Requestsmysql.global_status.innodb_buffer_pool_read_requestsThe number of logical read requests.Count
Availabilitymysql.global_status.availabilityWhether or not a connection can be made to the databasePercent
Statusmysql.global_status.statusA status of AVAILABLE is returned if we can query the databaseState
Uptimemysql.global_status.uptimeThe time in seconds that the MySQL server has been running since it was started.Second
CPU Usermysql.infrastructure.cpu.userThe percentage of CPU time spent in user mode.Percent
CPU Systemmysql.infrastructure.cpu.systemThe percentage of CPU time spent in system mode.Percent
Memorymysql.infrastructure.memoryThe amount of memory used per each code area.Byte
Waits IOmysql.waits.waits_io.countThe number of times that the server has waited for an I/O operation to complete.Count
Waits IO Timemysql.waits.waits_io_time.countThe total time the server has waited for I/O operations to complete.MilliSecond
Waits Syncmysql.waits.waits_sync.countThe number of times that the server has waited for a synchronization operation to complete.Count
Waits Sync Timemysql.waits.waits_sync_time.countThe total time the server has waited for synchronization operations to complete.MilliSecond
Full version history
ReleaseDate
New in this version:
  • Added ALERT_TEMPLATES for anomaly detectors in the Davis Anomaly Detection app.
Version 2.1.10
  • Fixed legend in Network DQL chart
  • Internal metadata update
Version 2.1.8
  • Replace cpu_utime_abs and cpu_system_abs with cpu_utime_pct and cpu_system_pct to accurately represent the average CPU usage taking in consideration the amount of CPU cores in the machine.
Version 2.1.7
  • Add metadata for the "Queries" metric.
Breaking changes/action required:
Added new top_queries feature set to collect slow query data via performance schema.
Please see "Collecting Top Slow Queries" section of Hub documentation for instructions to enable monitoring.
Existing feature set slow_queries will be deprecated in a future release.
  • Added 2 new metrics for cache hit ratio: mysql.global_status.innodb_buffer_pool_reads, mysql.global_status.innodb_buffer_pool_read_requests
  • Updated display name of server_version instance attribute to "DB Instance Version"
  • Added Gen3/Platform dashboard "MySQL Overview"
  • Added dt.security_context attribute to entities created by this extension
Version 2.1.3
  • Added server_version as metric dimension for global_status metrics, and instance entity attribute
Version 2.1.2
  • Add variables for the data collection frequency
Version 2.1.1
  • Fix an issue where the wait times metrics were not correctly converted to Milliseconds
Changes
  • The bytes sent visualization no longer shows negative values
Version 2.0.6
🚀 Features
  • There is a now a SAME_AS relationship between a MySQL instance and its Process Group Instance.
Fixed in this version:
  • Sorting SQL statements would produce duplicate results
Version 2.0.1
  • Add support for execution plan fetching, please check the hub page for details
  • Add screen definitions for the 3rd gen platform
Note: these features require Activegate 1.293+
Version 1.1.3
  • Fix an issue with the configure extension link in the overview dashboard
Version 1.1.2
Add metrics:
  • mysql.global_status.availability
  • mysql.global_status.status
Version 1.1.1
  • Fix an issue where MySQL entities were created from unrelated logs
Version 1.1.0
  • Add CPU metrics
  • Add Memory metrics
  • Add Slow Queries (log events)
Version 1.0.0
  • First release, instance and database metrics
Dynatrace Hub
All (812)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityDigital ExperienceBusiness Observability
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Analyze abnormal system behavior and performance problems detected by Davis AI.
Logs logo
Logs
Security Investigator logo
Fast and precise forensics for security and logs on Grail data with DQL queries.
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Davis Anomaly Detection logo
Detect anomalies in timeseries using the Davis AI
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Automate tasks in your IT landscape, remediate problems, and visualize processes
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Overview logo
Security Overview
Get a comprehensive overview of the security of your applications.
Code-Level Vulnerabilities logo
Detect vulnerabilities in your code in real time.
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Observability for Developer on Jetbrains logo
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
