Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
[Deprecated] Kubernetes PVCs[Deprecated] Kubernetes PVCs
Monitor your Kubernetes persistent volume claims and alert on capacity limits.
Extension
Free trialDocumentation
  • Product information
  • Release notes
Overview
This extension is deprecated with Dynatrace 1.294 and will not work anymore with Dynatrace 1.296. For replacement of this extension, check out the following community guide.
This is an extension for monitoring Kubernetes persistent volume claims. It comes with an out-of-the-box dashboard and pre-configured alerts for ease of use.
Use cases
  • Monitor Kubernetes persistent volume claims for disk usage and capacity.
  • Alert on disk space growth rates (for example, detect log spam).
  • Create custom dashboards and alerts using volume stats metrics exposed by the kubelet.
Details
Setup
Enable persistent volume claim monitoring in Dynatrace
In your Dynatrace environment, go to Kubernetes > Cluster > Settings and turn on Monitor persistent volume claims.
The following three kubelet metrics are then ingested into Dynatrace:
  • kubelet_volume_stats_capacity_bytes
  • kubelet_volume_stats_available_bytes
  • kubelet_volume_stats_used_bytes
Go to the Metrics browser in your Dynatrace environment and verify that these metrics are there.
Add extension to environment
To add this extension to your environment, select Add to environment on the page of this extension in the Dynatrace Hub.
You will then find an out-of-the-box dashboard and pre-configured alerts. Go to Dashboards > Kubernetes persistent volume claims in Dynatrace to view key metrics of your persistent volume claims.
Activate metric events for alerting
This extension comes with 4 alerts covering the Used disk space growth rate use cases. These alerts are pre-configured for absolute (byte) and relative (percent) thresholds featuring critical and soft limits.
To activate the alerts
  1. Go to Settings > Anomaly detection > Custom events for alerting in your Dynatrace environment.
  2. Find the following Kubernetes persistent volume claims alerts:
    • Increased growth rate: Notifies you if a persistent volume claim's used disk space is constantly increasing (for example, detect log spam).
  3. If necessary, select the Edit button to customize the alert conditions.
  4. Activate an alert to get problem notifications.
Problem detection
Problems raised by the Kubernetes persistent volume claim alerts are listed in your Problems feed. These problems feature the impacted Kubernetes cluster entity, the Kubernetes namespace name, and the Persistent volume claim name. The Impacted infrastructure component tile gives details about the affected Kubernetes resources and violated thresholds.
Disabling
As persistent volume claim monitoring is subject to DDU consumption, it is important to stop it by disabling the Monitor persistent volume claim option in your Kubernetes cluster settings.
Compatibility information
  • Dynatrace version 1.262+
  • ActiveGate version 1.261+
The following permissions must be given on Kubernetes side:
  • Containerized "in-cluster" ActiveGate: list nodes, get nodes/metrics
  • External "outside-cluster" ActiveGate: list nodes, get nodes/proxy
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Extension content
Content typeNumber of items included
alerts
4
metric metadata
3
dashboards
1
Customer story Abercrombie and Fitch
“Most other solutions are blind to containerized environments and struggle to instrument Kubernetes and Red Hat OpenShift. Dynatrace was purpose-built for these environments, giving us instant answers and out of the box value from day one.”
Jay Summerlot
IT Director
Read customer story
Abercrombie and Fitch logo
Related to [Deprecated] Kubernetes PVCs
Red Hat OpenShift logo
Red Hat OpenShift
Harness automation and AI to simplify observability on OpenShift at scale.
Full version history
ReleaseDate
  • Add deprecation notes to PVC dashboard and PVC alerts.
  • PVC Dashboard shipped with this extensions now links to the new builtin PVC dashboard.
  • Remove low disk space alerts as they are now part of the Kubernetes 'out-of-the-box' alerting
  • Fixed the percentage calculations for both the ‘Top 10 used…’ and the ‘Top 10 available…’ tiles.
  • Fixed the capacity, usage, and count pie charts.
  • Fixed metric expressions in metric events.
  • Updated the documentation.
  • Improved wording on the PVC dashboard.
  • Added a new tile on the PVC dashboard showing the top 10 used volume space in percent.
  • Improved the Kubernetes persistent volume claims dashboard.
  • Dashboard filters for Kubernetes cluster, namespace and persistent volume claim.
No release notes
Dynatrace Hub
All (814)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityDigital ExperienceBusiness Observability
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Analyze abnormal system behavior and performance problems detected by Davis AI.
Logs logo
Logs
Security Investigator logo
Fast and precise forensics for security and logs on Grail data with DQL queries.
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Davis Anomaly Detection logo
Detect anomalies in timeseries using the Davis AI
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Automate tasks in your IT landscape, remediate problems, and visualize processes
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Overview logo
Security Overview
Get a comprehensive overview of the security of your applications.
Code-Level Vulnerabilities logo
Detect vulnerabilities in your code in real time.
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub CoPilot Coding Agent logo
GitHub Copilot Custom Agent
Observability for Developer on Jetrains logo
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
