Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
GitLabGitLab
GitLab
GitLab
Amend files in GitLab repositories, trigger pipelines, and manage issues.
App
Free trial
- Trigger pipeline runs in a GitLab by defining project, branch, and build parameters
- Create or update issues in GitLab
- Query status of pipeline runs
- Combine GitLab workflow actions with notifications or quality gate validations- Follow a GitOps-compliant approach and amend configuration files in the underlying state repository
- Retrieve files from a GitLab repository
- Use David Analyzer to predict the required PVC size
- Create and update issues in GitLab according to the remediation progress
- Update file and create merge request
  • Product information
  • Release notes
Overview
Integrate your Dynatrace environment with GitLab to orchestrate pipeline runs, check their status, and create and update issues. For GitOps-compliant automation and remediation, retrieve files from repositories, update files in a state repository, and make merge requests.
Use cases
This enables you to:
  • Integrate Dynatrace with the GitLab platform to trigger a pipeline run, receive the status of a pipeline
  • Create issues in GitLab, search for available, resolve, edit and comment on issues
  • Perform GitOps-compliant automation and remediation scenarios, for example, to rightsize a PVC by amending the configuration in the underlying state repository
Get started
Follow the instructions detailed in Dynatrace Documentation.
Ensure that you have installed GitLab for Worfklows, that outbound connections are configured, and that the connection to GitLab is authorized.
If your GitLab platform is behind your firewall, configure EdgeConnect to tunnel the traffic securely.
Details
GitLab enables users to orchestrate pipeline runs based on Dynatrace insights and modify files in repositories for GitOps-compliant automation and remediation:
Define various incident triggers:
  • Use the power of DQL and leverage events to react to any problem, security incident or attack, to trigger a pipeline run
  • Use Biz-Events as a trigger to react on extended events like a deployment event, failed release validation with Site Reliability Guardian, specific logs messages, or external system events
  • Define a scheduler for periodic tasks
Pipeline Orchestration
  • Trigger a new pipeline run
  • Get pipeline status
Issue management
  • Search for available issues to prevent duplicates and comment on available issues
  • Edit or resolve issues, assign issues to specific users or add descriptions
Repository Management
  • Get File content
  • Create a new file, update or delete an existing file in your repository
  • Create a merge request, lists merge requests, update or merge and existent merge request
Dynatrace
More Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to GitLab
Workflows logo
Workflows
Automate tasks in your IT landscape, remediate problems, and visualize processes
Live Debugger logo
Live Debugger
Get real-time debug data from production or any remote environment
Full version history
ReleaseDate
This maintenance release includes updated dependencies to ensure optimal performance and security.
This maintenance release improves the stability of the GitLab connector and includes updated dependencies to ensure optimal performance and security.
This release introduces an enhanced fallback mechanism to the GitLab connector, improving reliability when working with existing connections. You can now access GitLab functionality in Workflows even when connection details cannot be retrieved. The connector automatically switches to expression mode in these scenarios, providing greater flexibility and resilience for your GitLab integrations.
  • Updated dependencies
2.0.2
2.0.1
  • Improved visual fidelity of connection management in modals
2.0.0
  • Migrated to owner based access control (ACL)
  • Disable request retries
2.0.1
Patch Changes
2.0.0
Major Changes
Minor Changes
2.0.0
Major Changes
Minor Changes
1.3.2
Patch Changes
  • Abbreviated help texts
1.3.1
Patch Changes
  • The "Edit Issue" action will not fail when a title is missing. If unset, the title will be kept as-is.
1.3.0
This release brings a new Workflow action to create notes for merge requests.
1.3.1
Patch Changes
1.3.0
1.3.0
1.2.0
Minor Changes
  • App is headless again. To control your connections, please use the Settings app.
Patch Changes
  • Updated the dropdowns for merge requests, branches, pipelines, and issues to be input fields instead.
1.1.4
Patch Changes
  • Show a loading indicator on dropdowns in workflow actions while data is fetched
1.1.3
Patch Changes
  • Renaming of app to "GitLab"
  • Adapted URL placeholder text
1.1.2
Patch Changes
1.1.1
Patch Changes
  • Fixed "Learn more" URL
1.1.0
Introduce a new, streamlined connection management experience with a modernized interface. This update makes adding and editing connections directly within workflows easier and provides connection control and convenience in one place.
Minor Changes
  • Fix connection schema: add proper sub-type to URL
Patch Changes
  • Fix: Add NO_WHITESPACE constraint to URL in settings schema
1.1.3
Patch Changes
1.1.2
Patch Changes
1.1.1
Patch Changes
1.1.0
Minor Changes
Patch Changes
1.1.2
Patch Changes
1.1.1
Patch Changes
1.1.0
Minor Changes
Patch Changes
1.0.0
  • First major release
Patch Changes
  • Improvement: made the "Project" input field clearer
  • Improvement: Validate action payloads
  • Improvement: Filter merged/closed merge requests in merge merge request action
0.2.2
  • maintenance release
0.2.1
  • wrap API response in action results
  • encode file path parameter
  • Limit "list issues" and "list merge requests" action responses to 30 items
0.2.0
  • Breaking: connections have been changed from an ordered list to an unordered list. This was done in preparation for better ACL support. However, inserting connections via API or Monaco using insertAfter will no longer be possible.
Minor Changes
  • Add new actions to list, create update, or merge a single merge request
  • Add new actions to get, create, update, or delete a file
Patch Changes
  • Improved error messages for workflow actions
  • Let the workflow action fail if it encounters an error
  • Update settings schema descriptions
  • Update app icon and description
0.1.0
This is the initial release of GitLab for Workflows.
Dynatrace Hub
All (812)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityDigital ExperienceBusiness Observability
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Analyze abnormal system behavior and performance problems detected by Davis AI.
Logs logo
Logs
Security Investigator logo
Fast and precise forensics for security and logs on Grail data with DQL queries.
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Davis Anomaly Detection logo
Detect anomalies in timeseries using the Davis AI
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Overview logo
Security Overview
Get a comprehensive overview of the security of your applications.
Code-Level Vulnerabilities logo
Detect vulnerabilities in your code in real time.
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Observability for Developer on Jetrains logo
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
