Allocated Capacity (GB) | storage.dell.powermax.array.AllocatedCapacity | - | GigaByte |
BE IOs/sec | storage.dell.powermax.array.BEIOs | - | Count |
BE Utilization | storage.dell.powermax.array.BEUtilization | - | Percent |
Cache Balance | storage.dell.powermax.array.Cache_Balance | - | Percent |
Capacity of R1 Cache Slots in Use | storage.dell.powermax.array.CapacityR1CacheSlotsInUse | - | KiloByte |
Capacity of R2 Cache Slots in Use | storage.dell.powermax.array.CapacityR2CacheSlotsInUse | - | KiloByte |
DA Balance | storage.dell.powermax.array.DA_Balance | - | Percent |
DX Balance | storage.dell.powermax.array.DX_Balance | - | Percent |
Data Reduction Ratio on Reducible | storage.dell.powermax.array.DataReductionRatioOnReducible | - | Count |
Percent Disk Busy | storage.dell.powermax.array.DiskUtilization | - | Percent |
EFD Balance | storage.dell.powermax.array.EFD_Balance | - | Percent |
FC Balance | storage.dell.powermax.array.FC_Balance | - | Percent |
FE Utilization | storage.dell.powermax.array.FEUtilization | - | Percent |
FE Balance | storage.dell.powermax.array.FE_Balance | - | Percent |
Host IOs/sec | storage.dell.powermax.array.HostIOs | - | Count |
Host Throughput | storage.dell.powermax.array.HostMBs | - | MegaBytePerSecond |
Local WP Count | storage.dell.powermax.array.LocalWPCount | - | Count |
Local WP Used Capacity | storage.dell.powermax.array.LocalWPUsedCapacity | - | MegaByte |
Number of R1 Cache Slots in Use | storage.dell.powermax.array.NumberR1CacheSlotsInUse | - | Count |
Number of R2 Cache Slots in Use | storage.dell.powermax.array.NumberR2CacheSlotsInUse | - | Count |
Data Reduction Ratio | storage.dell.powermax.array.OverallCompressionRatio | - | Count |
Percent Cache WP | storage.dell.powermax.array.PercentCacheWP | - | Percent |
Percent Hit | storage.dell.powermax.array.PercentHit | - | Percent |
Percent Meta Data Backend Used | storage.dell.powermax.array.PercentMetaBEUsed | - | Percent |
Percent Meta Data Frontend Used | storage.dell.powermax.array.PercentMetaFEUsed | - | Percent |
Percent Meta Data Replication Used | storage.dell.powermax.array.PercentMetaRepUsed | - | Percent |
Percent Meta Data System Used | storage.dell.powermax.array.PercentMetaSystemUsed | - | Percent |
Percent Reads | storage.dell.powermax.array.PercentReads | - | Percent |
Percent Writes | storage.dell.powermax.array.PercentWrites | - | Percent |
RDFA WP Count | storage.dell.powermax.array.RDFA_WPCount | - | Count |
RDF Utilization | storage.dell.powermax.array.RDFUtilization | - | Percent |
RDF Balance | storage.dell.powermax.array.RDF_Balance | - | Percent |
Read RT | storage.dell.powermax.array.ReadResponseTime | - | MilliSecond |
SATA Balance | storage.dell.powermax.array.SATA_Balance | - | Percent |
SCM Balance | storage.dell.powermax.array.SCM_Balance | - | Percent |
System Max WP Limit Capacity | storage.dell.powermax.array.SystemMaxWPLimitCapacity | - | MegaByte |
System Max WP Limit | storage.dell.powermax.array.SystemMaxWPLimit | - | Count |
System WP Events/sec | storage.dell.powermax.array.SystemWPEvents | - | Count |
System WP Count | storage.dell.powermax.array.WPCount | - | Count |
System WP Used Capacity | storage.dell.powermax.array.WPUsedCapacity | - | MegaByte |
Write RT | storage.dell.powermax.array.WriteResponseTime | - | MilliSecond |
