Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Davis Anomaly DetectionDavis Anomaly Detection
Detect anomalies in timeseries using the Davis AI
App
Try in PlaygroundDocumentation
Get an overview of all available anomaly detectors.Create anomaly detectors according to your business requirements.Start to verify convertible metric selector configurations from metric events and transform it to an anomaly detector.
  • Product information
  • Release notes
Overview
The Anomaly Detection App, seamlessly integrated within Dynatrace, focuses on enhancing timeseries monitoring through real-time analysis of DQL queries.
This app offers a specialized focus on detecting and alerting on anomalies based on multiple anomaly detector: - fixed threshold, auto-adaptive, or seasonal models — allowing for tailored monitoring that suits various patterns and needs.
Use cases
Davis Anomaly Detection enables you to:
  • Customize an anomaly detector for your specific requirements either coming from observability, security, or business perspective.
  • Create an anomaly detector on time series regardless of its origin—whether it’s generated with makeTimeseries from events, bizevents, logs, or other sources.
  • Leverage DQL for effective Anomaly Detection
  • Use one of the anomaly detection analyzers based on your timeseries behavior.
    • Static threshold anomaly detection
    • Auto adaptive threshold anomaly detection
    • Seasonal Baseline anomaly detection
  • Define your event template with {placeholder} hints and key: value essential information for the subsequent process.
Get started
Davis Anomaly Detection comes preinstalled with all Dynatrace SaaS environments
We recommend that you open Davis Anomaly Detection and run through the Getting started to become familiar with it. The Getting started appears when you open Davis Anomaly Detection for the first time. You can return to it anytime by selecting the help menu (?) in the upper-right corner of the app.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Davis Anomaly Detection
Workflows logo
Workflows
Automate tasks in your IT landscape, remediate problems, and visualize processes
Dashboards logo
Dashboards
Notebooks logo
Notebooks
More resources
Observability Clinic: Introduction to Anomaly Detection based on DQL
David walks you through a full end-to-end scenario of leveraging the Davis AI Analyzer and configuring custom anomaly detection events.
Watch video
Observability Clinic: Anomaly Detection on 5 Pillars of Data Observability
In this Observability Clinic, David and Wolfgang explain how Davis Anomaly Detection can be applied to the 5 Pillars of Data Observability: Freshness, Distribution, Volume, Schema, and Lineage.
Watch video
Observability Clinic: Elevating Security with Dynatrace Davis Anomaly Detection
In this episode, David and Gerhard share how to use Davis Anomaly Detection for Security use cases such as threat detection or identifying unusual behavior.
Watch video
Full version history
ReleaseDate
1.22.0
Minor Changes
  • Filtersegment support changes behind feature flag
Patch Changes
1.21.0
Minor Changes
  • Fallback to user email and then UUID if Firstname Lastname could not be resolved
  • Improved 403 error message in authorization modal
  • Support davis:analyzer:execute consent
  • Support lookup table permission
Patch Changes
  • Fix that DavisAnalyzer could not handle anyOf/oneOf schemas
  • Fix codemirror version
1.20.0
Patch Changes
  • Fix uppercasing for UUID/ID for table actions
  • Fixed that old requests were not properly aborted when changing filter too fast
1.19.0
Minor Changes
  • Add copy uuid context menu action for owner and actor
  • Remove support for old anomaly detector wizard modal
Patch Changes
  • Fixed that owner/actor filter with non-accessible uuid did not show anything as the filter
  • Fix that scanned bytes abbreviation was using the wrong postfix notation
1.18.2
Minor Changes
  • Prepare japanese translation support
  • Make all AD table columns resizable
  • Updated Ready-made dashboard to allow examining contents of an alerting config without navigating away
  • Query validation now ignores scalar values when checking for multi metric queries
  • Local FF override is not only available for DT users
Patch Changes
  • Fix CVE-2025-7783
  • Update dt logger library
  • Change column header alignment for status column from center to left
  • Fixed that table filter had spacing between it and table
  • Fixed that execution status was reloaded when adding empty filter
1.16.0
Minor Changes
  • Add possibility to copy config and object id from title column action
  • Add vertical dividers to datatable to better seperate columns
  • Migrated to DataTableV2 in MetricsEventModal
Patch Changes
  • Fix that event template would be empty in addon intent
  • Change log level of user state errors
  • Fix e2e test with new Open With modal
  • Fix that sonar did not get test coverage report
  • Fix error handling when policy request fails in modal intent
  • Fix that pressing the Suggest Value Button would crash the page
  • Fix that source entity extraction did not run in addon intent
1.15.0
Minor Changes
  • Show actor update warning modal when editing AD in addon intent
  • Enabled multi column sort by using shift when sorting columns
  • Show source app in "scope disabled" message in addon intents
  • Show edit successful message when editing an AD in addon intent
  • Automatically set smartscape source based on dimension splitting
Patch Changes
  • Fixed that title in addon intent summary popup could be empty
  • Fixed typo in first page of the micro guide
  • Fixed that DQL query in preview was not properly synced to dql query in AD
  • Fixed that you could not open the same AD twice in a row
1.14.1
Minor Changes
  • Introduced a ready-made dashboard to show an overview of Anomaly Detector health
  • Added possibility to pass title, description, and event template to create intent
  • Add routing and wizard to addon intent
  • Restyle addon intent to get rid of the modal in modal
  • Add link to health dashboard from execution status popup
  • Mark query as readonly when opening addon intent
  • Show "Not everything will be saved" alert when leaving the intent modal after AD is created
  • Show appropriate toast message on duplicate when AD limit reached
  • Added queryOffset as an input property for create intent
  • Open preview in new tab when opening from modal intent
  • Update microguide pictures to new AD wizard
  • Replaced occurrences of 'alert' in auth and confirmation modal of the addon intent
Patch Changes
  • Fixed that execution state PENDING was shown as ERROR
  • Use the correct ('accent') variant for save button in V2 modal
  • Update strato-components and starto-components-preview
  • Fixed dashboard error when loading AD data for the whole week
  • Added summary popup to create AD addon intent
  • Add authorization missing warning modal to addon intent
  • Fixed missing permission error handling when setting user app state
  • Fixed that Jenkins was unable to deploy PR preview because source maps were too big
1.12.0
Minor Changes
  • Introduced new Anomaly Detector modal for viewing/editing/creating. Learn more
  • Changed pagination page sizes to be in line with DataTable guideline
  • Adapted default event description to contain some markdown text
1.11.1
Minor Changes
  • Added copy/open-with cell actions to table
  • Opening wizard is now available from interactive row
  • Update message of 1 minute interval validation
  • Added default event.description when creating new anomaly detectors
  • Fixed that status column was not capitalized in visibility menu
  • Update app header to comply with guidelines
  • Added possibility to enable more scopes for app
Patch Changes
  • Updated @dynatrace/testing-platform-playwright to solve CORS related vulnerability
  • Fixed analyzer validation failing if generalParameters are set in intent
  • Fixed that validation could crash after updating query when no sourceEntity was set
  • Fix missing error catch when parsing filters from url
  • Make fixed threshold sdk test more robust
  • Improved logging in useHandleOpenExistingIntent handler when id is not set
1.10.0
Minor Changes
  • Enable "storage:spans:read" permisssion for span queries in anomaly detectors
Patch Changes
  • Fix settings endpoint error handling
1.9.1
Patch Changes
  • Event template suggestion now only starts after typing {
  • Show IAM policy statement to gain access to anomaly detectors
1.9.0
Minor Changes
  • Add information to all available execution status
  • Added aria-label and roles to improve a11y
1.9.0
Minor Changes
1.8.0
Minor Changes
  • Don't show {threshold} & {baseline} placeholder for seasonal model
  • Highlight anomaly detector row in data table when hovering over it
  • Validate for mulitple metrics
  • Persistent filters across sessions
  • Showing execution status failures now summarizes the result
  • Added possibility to copy missing permissions for settings object read and write
Patch Changes
  • fix multiple metric query validation
  • Do not consider .name for source property auto update
  • Fix snyk vulnerability
  • Switch to DataTableV2
  • fix filter persisting update problems
  • fix source entity replacing
1.6.1
Minor Changes
  • Set source entity based on entity splittings
  • Allow "Open with" with for read only user
  • Use green icon for successful status
  • Update davis icon used in the banner
Patch Changes
  • Remove unused permission
  • Fix invisible value suggestions for event template
1.4.1
Minor Changes
  • 3e3bb47 Fix actor save/change when modifying config
  • e4c0b6e: Fixed for davis merge field when migrating ME to AD
1.4.0
Minor Changes
  • b7fd76d: Do not allow span queries in anomaly detectors
  • c7649ca: Not found page added
  • 7276c5e: Support service users as actors and show warnings when actor changes
1.3.0
Minor Changes
  • 86e8344: Update micro guide screenshots
Patch Changes
  • eea0aaf: Extend the AD app settings intent to listen on the schema id
  • cdacb52: fix readonly workaround not working as expected
  • 6387ad7: Dont log warnings for microguide requests failed with 5xx
  • 3dd89c5: Improve log when validation result does not have a message property
  • 912c226: Refine bulk transpile query error handling
  • 88cfaeb: fix intent bug
1.2.1
Minor Changes
  • Show scanned bytes estimation in creation wizard
  • Show scanned bytes in anomaly detector table
  • Anomaly detector status considers last modification
  • Open status events in a notebooks preview
1.1.2
Patch Changes
  • Fixed when query validation would not detect sub 1 minute intervals
1.1.1
Patch Changes
  • 0aaa411: Fix that consent modification can affect other users consents
  • a0bb1f2: Fix multiple bindings handling: cleanup duplicates after query
  • 3cca716: Limit filter fields lengths to avoid settings object query to fail
Minor Changes
  • 5d10393: Lower log level for failed cancelled query validations
1.0.0
Initial release of Anomaly Detection App
Dynatrace Hub
All (814)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityDigital ExperienceBusiness Observability
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Analyze abnormal system behavior and performance problems detected by Davis AI.
Logs logo
Logs
Security Investigator logo
Fast and precise forensics for security and logs on Grail data with DQL queries.
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Davis Anomaly Detection logo
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Overview logo
Security Overview
Get a comprehensive overview of the security of your applications.
Code-Level Vulnerabilities logo
Detect vulnerabilities in your code in real time.
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub CoPilot Coding Agent logo
GitHub Copilot Custom Agent
Observability for Developer on Jetrains logo
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
