Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Check Point FirewallCheck Point Firewall
Gain insights into the performance of your Check Point Firewall devices.
Extension
Free trialDocumentation
A New Overview Dashboard is included for Check Point Firewalls and their interfaces, giving you an overview of the monitoring coverage. Use this as a starting point for troubleshooting and further drilldowns into your Check Point Firewall data.Analyze key Check Point device information in the Infrastructure and Operations app.Included Unified Analysis Screens give an overview of device specific Check Point metrics, bundled with the extension.An Classic Overview Dashboard is included for Check Point Firewalls and their interfaces, giving you an overview of the monitoring coverage. Use this as a starting point for troubleshooting and further drilldowns into your Check Point Firewall data.
  • Product information
  • Release notes
Overview
This extension leverages the SNMP protocol to provide a complete solution to monitor Check Point Firewall Devices. The complete configuration is provided out-of-the-box.
This is intended for users, who:
  • Would like to monitor health state and performance of their Check Point Firewall devices and provide unified analysis for Ops, DevOps and IT Admins.
This enables you to:
  • Monitor health and performance of your Check Point Firewall devices
  • Use an included alert configuration to be alerted if a monitored interface goes into a 'down' state.
  • Set up alerts to be notified by traffic anomalies
Use cases
  • Monitor Check Point Firewall devices by polling data for Network Devices and Interfaces.
  • Enable alerting on detected anomalies
  • Use with the Infrastructure and Operations App for an overview of all monitored Network Devices in the environment.
Get started
For more information on the installation and configuration, please see Check Point Firewall extension in the Dynatrace Documentation.
Details
Compatibility information
  • This extension is to be used with Check Point Firewalls only.
  • SNMPv2c and SNMPv3 supported only.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
-com.dynatrace.extension.network_device.sysuptime--
-com.dynatrace.extension.network_device.cpu_usage--
-com.dynatrace.extension.network_device.memory_used--
-com.dynatrace.extension.network_device.memory_free--
-com.dynatrace.extension.network_device.if.bytes_in.count--
-com.dynatrace.extension.network_device.if.bytes_out.count--
-com.dynatrace.extension.network_device.if.status--
-com.dynatrace.extension.network_device.if.in.errors.count--
-com.dynatrace.extension.network_device.if.in.discards.count--
-com.dynatrace.extension.network_device.if.out.errors.count--
-com.dynatrace.extension.network_device.if.out.discards.count--
Physical component statecheckpoint.firewall.component.stateA state metric representing the details of physical components. This is used to collect details about the device stack. Value is always 1; use the dimensions to view details.NotApplicable
Device entity attributescheckpoint.firewall.entity_attributesConstant value of 1 used for reporting entity attributes at a lower frequencyUnspecified
-com.dynatrace.extension.network_device.if.in.multicast_pkts.count--
-com.dynatrace.extension.network_device.if.out.multicast_pkts.count--
-com.dynatrace.extension.network_device.if.in.broadcast_pkts.count--
-com.dynatrace.extension.network_device.if.out.broadcast_pkts.count--
-com.dynatrace.extension.network_device.if.in.ucast_pkts.count--
-com.dynatrace.extension.network_device.if.out.ucast_pkts.count--
-com.dynatrace.extension.network_device.if.lastchange--
-com.dynatrace.extension.network_device.if.in.crc_errors.count--
Disk percentcheckpoint.firewall.disk.percentPercent of free spacePercent
Users connectedcheckpoint.firewall.users.connectedNumber of connected usersCount
Accepted packetscheckpoint.firewall.packets.accepted.countAccepted packetsCount
Dropped packetscheckpoint.firewall.packets.dropped.countDropped packetsCount
Logged packetscheckpoint.firewall.packets.logged.countLogged packetsCount
Rejected packetscheckpoint.firewall.packets.rejected.countRejected packetsCount
Number of connectionscheckpoint.firewall.connectionsNumber of connectionsCount
Peak number of connectionscheckpoint.firewall.connections.peakPeak number of connectionsCount
Active real memorycheckpoint.firewall.memory.active.realActive real memoryByte
Active virtual memorycheckpoint.firewall.memory.active.virtualActive virtual memoryByte
Free real memorycheckpoint.firewall.memory.free.realFree real memoryByte
Processor system timecheckpoint.firewall.cpu.time.systemProcessor system timeMilliSecond
Processor usagecheckpoint.firewall.cpu.usageProcessor usagePercent
Processor user timecheckpoint.firewall.cpu.time.userProcessor user timeMilliSecond
System uptimecheckpoint.firewall.sysuptimeThe system up time since boot, in system ticks (hundredths of a second)Count
Bytes incheckpoint.firewall.if.bytes.in.countNumber of octets received on the interfaceByte
Packets incheckpoint.firewall.if.packets.in.countNumber of packets received on the interfaceCount
Bytes outcheckpoint.firewall.if.bytes.out.countNumber of octets sent on the interfaceByte
Packets outcheckpoint.firewall.if.packets.out.countNumber of packets sent on the interfaceCount
Errors incheckpoint.firewall.if.errors.in.countNumber of packets with errors received on the interfaceCount
Errors outcheckpoint.firewall.if.errors.out.countNumber of packets with errors sent on the interfaceCount
Oper statuscheckpoint.firewall.if.status.operCurrent operational stateState
Admin statuscheckpoint.firewall.if.status.adminDesired state of interfaceState
Speedcheckpoint.firewall.if.speedEstimate of interface's current bandwidthBitPerSecond
Full version history
ReleaseDate
Bugfixes
  • Adjusted markdown link in Platform Dashboard to point to the Network devices section in the I&O app.
  • Adjusted DQL tiles in Platform Dashboard to point to the I&O app.
Enhancements
  • Updated entity links in Platform dashboards to redirect to the Infrastructure & Operations app.
Bugfixes
  • Adjusted required dimensions for entity creation to prevent null entities from being created.
Fixed in this version:
  • sys.name and mac.address dimensions are required on all network metrics and filtered for empty values. This caused unnecessary stress on topology engine.
  • Updated source rule for checkpoint:firewall to use checkpoint.firewall.entity_attributes for consistent entity naming.
✨ New in this version (1.1.0):
  • Added the following new metrics to the Advanced interfaces feature set:
    • com.dynatrace.extension.network_device.if.in.multicast_pkts.count
    • com.dynatrace.extension.network_device.if.out.multicast_pkts.count
    • com.dynatrace.extension.network_device.if.in.broadcast_pkts.count
    • com.dynatrace.extension.network_device.if.out.broadcast_pkts.count
    • com.dynatrace.extension.network_device.if.in.ucast_pkts.count
    • com.dynatrace.extension.network_device.if.out.ucast_pkts.count
    • com.dynatrace.extension.network_device.if.lastchange
  • Added the following new metrics to the default feature set:
    • com.dynatrace.extension.network_device.if.in.errors.count
    • com.dynatrace.extension.network_device.if.in.discards.count
    • com.dynatrace.extension.network_device.if.out.errors.count
    • com.dynatrace.extension.network_device.if.out.discards.count
āš™ļø Changed in this version:
  • Moved the metric checkpoint.firewall.entity_attributes to a new Entity attributes feature set.
  • Moved the metric checkpoint.firewall.component.state to a new Stack info feature set.
ā— IMPORTANT:
Make sure to toggle these new feature sets on in your configurations if you are using those metrics and properties, as they are no longer captured by default.
āš ļø Note:
  • This release requires a Minimum Dynatrace Version and Minimum ActiveGate version of 1.318.0 or higher.
New in this version:
  • Internal metadata updated.
Improved in this version:
  • Replaced checkpoint.firewall.memory.active.real and checkpoint.firewall.memory.active.virtual metric values with 64-bit OID alternatives.
    • com.dynatrace.extension.network_device.memory_used and com.dynatrace.extension.network_device.memory_freenow use 64-bit OIDs as well.
  • Changing the Unit on Memory metrics from KiloBytes to Bytes.
  • Added new metric for free real memory (checkpoint.firewall.memory.free.real).
  • Use the same OIDs for if.name dimension across the Generic Network Interface and Check Point Interface metrics.
New in this version
  • Added screens for latest Dynatrace.
  • Refined New Dashboard.
āš ļø IMPORTANT CHANGE:
Metrics in "default" feature set will always be enabled and cannot be disabled. These metrics are mandatory. Take extra caution configuring devices and interfaces for which you are collecting data. Make use of Interface filters to limit the number of interfaces, otherwise, all interfaces on the device will be collected by default. In case you do not wish to collect interfaces on your device, enter $eq(!) in the "Interface Name" filter field on the Feature Sets screen during configuration.
  • Default network metrics moved into the "default" feature set, specifically interface metrics.
āš ļø Special note when updating to this version:
  • You must disable the old "neighbor-discovery" feature set in order to update to this version.
  • Please review the metrics included with the default feature set and ensure it aligns with your previous monitoring footprint (default metrics are always enabled).
  • The "neighbor-discovery" feature set was removed. This is now handled by the SNMP Auto-discovery extension for any kind of device.
  • Security Context is applied to entities.
  • Initial Release
    • Requires Dynatrace Tenant Version >= 1.309
    • Requires ActiveGate Version >= 1.291
Dynatrace Hub
All (882)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
