Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Azure logsAzure logs
Azure logs
Azure logs
Get insights from Azure logs with Log Management and Analytics.
Technology
Free trialDocumentation
  • Product information
Overview
Azure log forwarding allows you to stream Azure logs from Azure Event Hubs into Dynatrace via an Azure Function App instance to analyze, build observability, and automate problem resolution.
Azure resource logs and activity logs are supported.
Azure log forwarding is performed directly through the Generic log ingestion API available on your SaaS tenant.
For Dynatrace Managed, or if an Environment ActiveGate is your choice for an endpoint in your local environment, install an ActiveGate
Get started
Set up the integration from Azure cloud to Dynatrace with the following steps:
  • Get a Dynatrace API token with the Ingest Logs scope to integrate with Dynatrace generic log ingest API.
  • Configure Azure log forwarder by following information and deployment instructions available on Azure Logs Dynatrace documentation
The following resources will be created by the Azure logs forwarder deployment script:
  • Storage account Microsoft.Storage/storageAccounts
  • Storage Account Blob Service Microsoft.Storage/storageAccounts/blobServices
  • Azure App Service plan Microsoft.Web/serverfarms
  • Azure Function App Microsoft.Web/sites
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Copy to clipboard
Dynatrace Hub
All (818)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityDigital ExperienceBusiness Observability
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Analyze abnormal system behavior and performance problems detected by Davis AI.
Logs logo
Logs
Security Investigator logo
Fast and precise forensics for security and logs on Grail data with DQL queries.
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Davis Anomaly Detection logo
Detect anomalies in timeseries using the Davis AI
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Automate tasks in your IT landscape, remediate problems, and visualize processes
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Overview logo
Security Overview
Get a comprehensive overview of the security of your applications.
Code-Level Vulnerabilities logo
Detect vulnerabilities in your code in real time.
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub CoPilot Coding Agent logo
GitHub Copilot Custom Agent
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
