Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Agentic Incident AnalysisAgentic Incident Analysis
Root cause, blast radius, and the fix, in one pass.
Technology
Free trialDocumentation
Root cause, blast radius, and the fix, in one pass.Ask once and get the problem summary with the root cause named.The agent investigates on its own and writes the analysis onto the problem.
  • Product information
Overview
Why did it break, and how to fix it? Root cause, blast radius, and the fix, in one pass.
Start from a conversation and the agent becomes your expert assistant, in Dynatrace Assist or through the Dynatrace MCP server, wherever you work. Or let it run autonomously: when a problem is automatically detected, the work that used to fill your first hour is finished before you even open the problem, and you get a named cause and a suggested remediation.
A ticket already arrives investigated. Root cause and a proposed fix are there before you open it, and recurring ones can be remediated with no person in the loop.
  • Understand what is happening. Surface the health picture and the patterns worth attention.
  • Identify the root cause. A named root cause with the supporting evidence, grounded in causal analysis and the Smartscape dependency graph.
  • Assess the impact. See the blast radius, whether it's isolated or hits the business, and what depends on it.
  • All the context you need. Logs, events, topology, spec changes, metrics in context.
  • Know what to do. Get the remediation steps, or a ticket, a pull request or a code fix, waiting on your approval.
Use cases
  • Deep root cause and impact analysis: investigate the root cause with blast radius, the real user impact, and why the alerts were merged into one problem.
  • Log pattern analysis: scan the log patterns on a workload and rank them by frequency and severity.
  • Root cause on demand: get the causing entity and the exact change behind it.
  • Release regression analysis: compare a problem's start time against the deployment history and name the exact commit that introduced it.
  • Hidden dependency discovery: find every app and endpoint calling a service.
  • Investigate from your IDE (MCP): ask Dynatrace from your IDE, through the Dynatrace MCP server, and get the production answer next to your code.
  • Route it to the service desk: the incident arrives in ServiceNow, Jira or Jira Service Management with the cause already named.
Get started
Ask interactively
  1. Enable generative AI and agentic AI for your environment and assign the permissions through a policy. See the getting started documentation.
  2. Open Dynatrace Assist and ask about a problem you own. To ask from your IDE or terminal, install the Dynatrace MCP server.
Run it autonomously
  1. Enable Dynatrace Intelligence for Workflows and build an agentic workflow triggered on problem events, starting from the ready-made agents.
  2. The agent investigates, and the workflow adds the trigger, the approval and the routing. Every agent runs as its own scoped service identity with allow-listed tools and approval gates. Route the result to the Problem, email, Slack, a ticket, or a Git repository.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Copy to clipboard
Related to Agentic Incident Analysis
Dynatrace Assist logo
Dynatrace Assist
Dynatrace MCP Server logo
Kubernetes Troubleshooting (Agentic Workflow) logo
Automated troubleshooting and root cause analysis of Kubernetes resources.
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Dynatrace Hub
All (948)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist
SRE Agent logo
SRE Agent
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
