Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
SNMP AutodiscoverySNMP Autodiscovery
SNMP Autodiscovery
SNMP Autodiscovery
Scan through your subnets and build an inventory of SNMP-enabled network devices
Extension
Free trialDocumentation
The "Generic network overview" dashboard offers a single pane of glass view over the key extension findings, including the extended network built through neighbor discovery.Build an inventory of all your network devices. Each device recommends a specialized extension that can provide monitoring insights.Reach your data easily through this convenient overview dashboard.
  • Product information
  • Release notes
Overview
This ActiveGate extension takes subnets and ranges of IP addresses along with SNMP credentials and scans through them to discover SNMP-enabled network devices. The devices are then reported as entities acting as an entry point to specialized extension configurations.
This is intended for users who:
  • Want to simplify the onboarding of network device monitoring in Dynatrace
  • Require a single pane of glass view over all network technologies
This extension enables you to:
  • Get an overview of all network devices, regardless of technology
  • Find out which Dynatrace Extension can best monitor each device
  • Access all extension network data in one place
Use cases
  • Build an inventory of SNMP-enabled network devices
  • Understand which extension Dynatrace recommends for further monitoring & insights
  • Enable the use of the Discovery & Coverage App for automatically setting up network monitors and extension configurations for the discovered devices
  • Understand your extended network in terms of device to device connectivity along with port & interface details
Compatibility information
  • SNMP v2c or v3 (supported parameters are detailed here)
  • Minimum ActiveGate version 1.280
  • Minimum Dynatrace version 1.280
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Extension content
Content typeNumber of items included
screen logs cards
1
screen layout
3
generic relationship
20
screen message cards
2
document dashboard
1
list screen layout
2
screen entities lists
2
metric metadata
25
screen chart groups
1
screen actions
4
dashboards
1
generic type
5
screen properties
3
Feature sets
Devices OKsfm.snmp_autodiscovery.devices_okThe amount of addresses that responded to the scanner query as part of a given configuration.Count
Devices scannedsfm.snmp_autodiscovery.devices_scannedThe total amount of addresses that were scanned by the extension as part of a given configuration.Count
Scan durationsfm.snmp_autodiscovery.scan_durationThe time the extension took to scan through all addresses that are part of a given configuration.NanoSecond
Full version history
ReleaseDate
🚀 Improved in this version (3.2.16):
  • Adjusted naming of interface dimensions for traffic metrics.
Fixed in this version:
  • Interfaces & Ports for network neighbor entities were not correctly created
Improved in this version:
  • Legacy com.dynatrace.extension.network_device.lldp_neighbor metric fully removed from the model and topology rules
✨ New in this version (3.2.13):
  • Added metric metadata definitions for unicast/multicast/broadcast packet transmission.
  • Added debug log flag in extension configuration for troubleshooting.
🚀 Improved in this version:
  • Improved detection of interface names in LLDP neighbor resolution.
    • Extension will now match detected network interfaces to discovered ports via MAC address and create a relationship.
    • If local(7) subtype is found, it will be treated as interface name.
🪲 Fixed in this version:
  • Corrected treatment of whitelisted devices that could lead to neighbor discovery being stopped.
✨ New in this version (3.2.10):
  • Added 2 new metric metadata definitions.
  • Network Device entities would be created for every IP Address, even if unresponsive
Improvements:
  • Neighbor discovery queries have been optimized for large devices with lots of interfaces
  • Specialized extension recommendations now include the extensions for HP H3C and ICF Switches
  • Entities created through neighbor discovery were missing relationships between them
  • Syslog data is linked to its own entity which is then linked to network:device to not overcrowd the Infrastructure & Operations App view
  • For neighbor discovery, in some cases, a Physical Port would be wrongly reported as an Interface in the logs & dashboard data.
🐛 Bugs fixed in this version:
  • Fixes bug in platform dashboard in which links were referencing the incorrect tenant
New in this version:
  • Security Context is applied to all entities. Do not configure this if you would rather control it from one of the specialised SNMP extensions (e.g. F5, Cisco, Juniper, etc.)
  • The metrics metadata was expanded to include Interface Errors (In/Out) and Discards (In/Out)
  • An ignore rule was configured for devices whose System Object IDs start with "1.3.6.1.4.1.8072.3.2". These typically identify full linux servers, so they shouldn't be considered as "network devices" to be discovered.
  • The Classic dashboard tile for log records would not fetch any records
New in this version
    • A new configuration switch has been added to enable Neighbor Discovery.
    • With this feature, every discovered device that is SNMP enabled will also be queried for Network Neighbors. Neighbors are other devices connected to the queried device which advertise themselves via LLDP protocol. It is down to each individual device to have this protocol enabled and accurately configured to broadcast correct data.
  • Platform dashboard
    • A "Generic network overview" dashboard is now available with the extension
    • This visualizes some of the key findings of the extension, along with the new network neighbors data.
  • Custom timeout
    • A new configuration field allows setting a custom timeout for SNMP operations
    • In cases where the extension is reporting "No SNMP response received before timeout" for device groups you know are SNMP enabled, you may increase the value past the default of 1 second to compensate for network & device latency.
    • ⚠️ Warning this proportionately increases the duration of the scan as every address will be awaited longer.
  • Lower cost from log ingestion
    • The extension now produces a more optimized log record format which is expected to reduce cost especially in situations where multiple configurations are created.
  • glibc dependency introduced by cryptography package was lowered to 2.17, allowing more Linux distributions to run the extension.
  • Bandwidth property on network:interface corrected to MegaBitPerSecond unit
  • oper.status dimension on some interface metrics was incorrectly labelled as "MAC address"
  • cryptography package explicitly listed as a dependency. This would cause "ciphering services not available" error on some installations.
  • Operational & Admin status attributes are missing for network:interface entity
  • Network devices are discovered even with partial data available
  • Extension log files contain a more detailed breakdown of SNMP errors seen across devices
  • Configuration parameter Performance profile renamed
  • Description & documentation for API Token updated to reflect new scopes required
⚠️ Breaking changes introduced:
  • The configuration parameter for Threads has been removed.
  • A new configuration parameter for Performance profile was introduced.
  • Due to these changes, a direct upgrade of your monitoring configurations will not be possible.
    All configurations will have to be recreated.
  • The extension can handle 25 times the amount of IPs, in the same amount of time.
  • The extension automatically adjusts processing to stay within ActiveGate performance profile limits.
  • Relationships between network interfaces and network ports would not be correctly identified
  • Support for Credential Vault when using SNMP v2 and v3 credentials
  • Topology model updated to use sys.name instead of device.name when naming network:device entity instances.
  • Network topology model was expanded to include neighbor discovery (LLDP) data
  • Additional routines added for relating network device entities to built-in topology
  • Entity UI was enabled for AppEngine usage
  • The network topology rules were enhanced to simplify the changes needed in other extensions to leverage the data
  • Additional rules were added to more reliably collect entity attributes
  • Devices already existing before the first scan would not receive configuration and group labels as entity attributes
  • self-monitoring feature set, which includes 3 diagnostic metrics:
    • Scan duration
    • Devices scanned
    • Devices OK
First public release.
Dynatrace Hub
All (810)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityDigital ExperienceBusiness Observability
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Analyze abnormal system behavior and performance problems detected by Davis AI.
Logs logo
Logs
Security Investigator logo
Fast and precise forensics for security and logs on Grail data with DQL queries.
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Davis Anomaly Detection logo
Detect anomalies in timeseries using the Davis AI
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Automate tasks in your IT landscape, remediate problems, and visualize processes
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Overview logo
Security Overview
Get a comprehensive overview of the security of your applications.
Code-Level Vulnerabilities logo
Detect vulnerabilities in your code in real time.
Security Posture Management
Threats & Exploits logo
Threats & Exploits
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
