Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Remote Unix Monitoring 2.0Remote Unix Monitoring 2.0
Extension that remotely collects Unix OS data by executing commands via SSH.
Extension
Free trial
A monitoring configuration example.The feature sets page of the configuration screens.The included overview dashboard.The remote Unix host view showing the collected properties.Top view of the Unix host screen showing cpu and memory metrics.A screen showing connection error events displayed.The process view showing top process log records.The process metrics on a remote Unix screen.
  • Product information
  • Release notes
Overview
Overview
Unix/Linux is often used to run critical applications. A OneAgent is the best way to monitor such systems, however this is not always possible. Legacy unsupported versions or agreements with vendors may prevent you from installing a OneAgent on these important hosts. In these cases you can use the Remote Unix Monitoring extension to collect valuable telemetry on your hosts and the applications they are running. It works by connecting to your Unix/Linux hosts over SSH and running commands.
Use cases
  • Monitor and alert on important host metrics
  • Monitor the availability and resource usage of your key processes and applications
  • Identify host availability issues
Details
Metrics
Review the list of feature sets to see which metrics are collected. Note that for some distributions different metrics/metric keys may be used for some types of metrics due to similar but not identical metrics being available on that distribution as compared to what is more commonly collected.
Log events
Top process data
When configured, details about the 'top' processes running over time will be ingested as log events. These will include more complete data about the process (including the process ID) as compared to what the metrics alone will provide.
Filtered process PID change
When monitoring a group of filtered processes, if the set of PIDs in that group changes an event will be reported.
Connection issues
An availability event will be reported in cases of connection issues to the target host.
Compatibility information
The following OSs are explicitly supported and can be selected in the configuration:
  • AIX
  • Centos
  • FreeBSD
  • HP-UX
  • MacOS
  • Oracle Linux
  • Red Hat Enterprise Linux (RHEL)
  • Solaris
  • Suse
Many other distributions such as Ubuntu can be monitored by selecting 'Debian Linux.'
As a goal of this extension is to provide visibility into systems that cannot be monitored by a OneAgent it does not have the same support policy as other areas of Dynatrace where we support what the vendor supports. Rather we try to support as many distributions as possible regardless of their support status to the best of our ability.
Installation
Requirements
  • Minimum Dynatrace environment and ActiveGate version 1.269
  • An OS in the listed of the supported distributions
  • SSH enabled and reachable from assigned ActiveGates
  • A user with permission to connect and run the required commands
    • No commands used require root/sudo privileges so as a security best-practice we advise against using a root account or a user with sudo privileges. A normal user is adequate and recommended.
  • Either a valid password or key for authentication
    • Note: Kerberos authentication (e.g. Centrify) is not supported for password authentication. In these cases using a certificate is recommended
Dynatrace configuration
Find 'Remote Unix Monitoring 2.0' in the in-product Extensions or Hub page and activate (if offline you can download the extension from this Hub page in the 'Versions' section and install as a custom extension).
Monitoring configurations
Once activated in your environment you can create monitoring configurations. Each monitoring configuration can have one or more remote unix target hosts configured.
First select the desired ActiveGate group that will run the monitoring configuration.
For each cluster configure a Remote Unix Endpoint:
  • Hostname: hostname or IP address to connect to
  • Port: port where the SSH server is listenening (default 22)
  • Host alias: an optional alias for the target host, defaults to hostname configured
  • Operating system
  • Authentication
    • Password: supports credential vault
    • Key contents: SSH private key contents as copy-pasted from key file
    • Key path: a path to a key file. Must be present and readable on any ActiveGate to work
  • Additional properties: additional properties to be added as dimensions to ingested metrics
  • Top process count: when reporting top process metrics how many should be collected (default 10)
  • Report as log events: report more detailed top process data as log events
  • Process filters: a set of process filters to collect filtered process data for
    • Group key: process group to which matches will be assigned
    • Pattern: regex to match the process commands
    • User: optional user filter
  • Mount filters: filteres to control which mounts to report metrics for
  • Advanced settings
    • Custom PATH: if the default non-login path does not have all required commands, specify a custom PATH to be used when looking for commands
    • SSH connection behavior: disconnect on each execution or reuse between runs and keep open
    • RSA2 algorithm: some older systems require RSA2 to be disabled. See here for details.
    • Top mode
      • Metrics that require top for process level metrics will be run in threads mode (-H) and report metrics at the process thread level
      • Can be used if in multi-processor environments percentages of CPU greater than 100% are reported
    • Max concurrent channels: Determines number of simultaneous channels that can be open over SSH connection. Default and Max: 5.
      • Some systems may experience channels errors due to simultaeous channels being used. In these cases you can try lowering this value.
    • Log command output: command output will be recorded in debug logs to assist with troubleshooting. DEBUG logging must be enabled.
Feature sets
Review the available feature sets to determine which you want to enable and collect. The enabled feature sets will effect which commands are run to avoid running commands that are not needed.
Troubleshooting
Required commands
Commands used are based on what is available in a 'vanilla' installation of the given OS, so typically no additional installs will be required.
Required commands must be available on the 'PATH' set for non-login shells, which can be different from login shells which is what you use when manually SSHing into a server. If you see log entries that commands are missing check that the command is available and that it is in the 'PATH' for non-login shells. If not, you can either correct this via configuration on the host or use the custom path configuration field to manually set a path to use.
You can test commands in non-login shells by running the ssh command with the command to run appended:
ssh <host> <command>
To view the path you can try:
ssh <host> 'echo $PATH'
For reporting the path it is important to use single quotes. Double quotes may cause the environment variable to show the value on your local system rather than the value on the remote host.
Debian Based Linux (Generic Linux)
  • vmstat
  • w
  • df
  • cat
  • top
  • pgrep
  • iostat
    • for Red Hat Enterprise Linux systems you may need to install the sysstat package to collect disk IO metrics. No alternatives that exist by default were found.
  • ip or netstat
    • older OSs don't have required stats in 'ip' command and will 'fall back' to netstat
Solaris
  • vmstat
  • w
  • df
  • netstat
  • ps
  • grep
  • prstat
  • kstat
  • mpstat
  • iostat
  • swap
  • prtconf
AIX
  • vmstat
  • w
  • df
  • netstat
  • ps
  • grep
  • svmon
  • mpstat
  • iostat
FreeBSD
  • vmstat
  • w
  • df
  • netstat
  • ps
  • top
  • grep
  • iostat
HP-UX
  • vmstat
  • w
  • df
  • netstat
  • ps
  • grep
  • swapinfo
  • top
  • sar
  • machinfo
Extension Logs
For some authentication errors you may need to check authentication/access logs on the target host for details as to why a connection is failing.
Debug logging should only be set when necessary and then reverted to avoid excessive logging.
Licensing
Licensing
There is no charge for obtaining the extension, only for the data (metrics & events) that the extension ingests. The details of license consumption will depend on which licensing model you are using. This will either be Dynatrace classic licensing or the Dynatrace Platform Subscription (DPS) model.
Metrics
License consumption is based on the number of metric data points ingested. The following formula will provide approximate annual data points ingested assuming all feature sets are enabled:
Calculation estimates yearly DDU usage:
(21 + (4 * <number of CPUs>) + (2 * <matching_filtered_processes>) + (2 * <process_groups>) + (3 * <matching_mounts>) + (8 * <network_interfaces>) + (2 * <disks>)) * 525.6
  • See description of 'Process filter' configuration for explanation of what a group and filtered processes will be
  • Matching mounts will be those that meet criteria of 'Mounts to include' and 'Mounts to exclude' configurations
Events
Each custom event reported will consume license. The number of reported custom events will be based on the frequency of things like connection errors where an availability event is reported.
Classic licensing
In the classic licensing model, custom events will consume Davis Data Units (DDUs) at the rate of .001 DDUs per metric data point.
Multiply estimated ingested log records by .001 to estimate DDU usage from log records.
Log records
Log records will be ingested for top process records if enabled based on the configured number of top process records once per minute.
Log management and analytics (powered by Grail)
License consumption is based on the size (in bytes) of data ingested & processed, retained, and queried so there is not a single formula to estimate the total consumption from this extension. Consult the log management and analytics documentation for details on the other dimensions that will effect license consumption.
Classic licensing
In the classic licensing model, log record ingestion will consume Davis Data Units (DDUs) at the rate of 100 DDUs per Gigabyte of log records ingested.
Log monitoring classic
In log monitoring classic, license consumption is based on the number of ingested log records.
Classic licensing
In the classic licensing model, log record ingestion will consume Davis Data Units (DDUs) at the rate of .0005 DDUs per ingested log record.
Multiply estimated ingested log records by .0005 to estimate DDU usage from log records.
Dynatrace
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Extension content
Content typeNumber of items included
screen logs cards
1
screen properties
1
metric metadata
51
screen layout
2
generic relationship
1
dashboards
1
list screen layout
2
screen chart groups
3
screen metric tables
11
generic type
2
screen events cards
1
screen entities lists
3
Feature sets
Zpool sizeremote_unix.zpool_sizeZpool total sizeByte
Zpool allocatedremote_unix.zpool_allocatedZpool space allocatedByte
Zpool freeremote_unix.zpool_freeZpool space freeByte
Zpool capacityremote_unix.zpool_capacityZpool used percentPercent
CPU Utilizationremote_unix.cpu_utilizationOverall CPU utilizationPercent
CPU Userremote_unix.cpu_userPercentage of time the processor spent executing user/application codePercent
CPU Systemremote_unix.cpu_systemPercentage of time the processor spent executing system/kernelPercent
CPU Idleremote_unix.cpu_idlePercentage of time the processor was idlePercent
Individual CPU user timeremote_unix.individual_cpu_time_userPercentage of time individual CPU spent executing user/application codePercent
Individual CPU system timeremote_unix.individual_cpu_time_systemPercentage of time individual CPU spent executing system/kernel codePercent
Individual CPU idle timeremote_unix.individual_cpu_time_idlePercentage of time individual CPU was idlePercent
Individual CPU iowait timeremote_unix.individual_cpu_time_iowaitPercentage of time individual CPU spent waiting on IO operationsPercent
Mount usedremote_unix.mount_usedMount space in useByte
Mount capacityremote_unix.mount_capacityOverall capacity of the mountPercent
Mount availableremote_unix.mount_availableMount space availableByte
Disk readremote_unix.disk_read_countAmount of data read from diskByte
Disk writeremote_unix.disk_write_countAmount of data written to diskByte
Disk read operationsremote_unix.disk_read_opsReads from diskPerSecond
Disk write operationsremote_unix.disk_write_opsWrites to diskPerSecond
Bytes per transferremote_unix.bytes_per_transferBytes per transferByte
Disk transfersremote_unix.transfersDisk transfersCount
Paged inremote_unix.paged_inMemory pages swapped in from diskPerSecond
Paged outremote_unix.paged_outMemory pages swapped to diskPerSecond
Physical memory freeremote_unix.physical_memory_freeAmount of memory free as seen by OSByte
Physical memory used percentremote_unix.physical_memory_used_percentPercentage of memory used as seen by OSPercent
Swap freeremote_unix.swap_freeAmount of swap space freeByte
Swap totalremote_unix.swap_totalTotal swap space available on systemByte
Swap used percentremote_unix.swap_used_percentPercentage of available swap space in usePercent
Swap used percentremote_unix.swap_free_percentPercentage of available swap space not in usePercent
Top process CPU usageremote_unix.top_process_cpuCPU usage of a 'top' resource consuming detected processPercent
Top process memory usageremote_unix.top_process_sizeMemory usage of a 'top' resource consuming detected processByte
Availabilityremote_unix.availabilityAvailability of host based on initial SSH connectionPercent
Waiting processesremote_unix.waiting_processesNumber of processes waiting to for processor timeCount
User countremote_unix.usersNumber of users on the systemCount
Load average (1 min)remote_unix.load_avg_1_minOne minute load averageCount
Load average (5 min)remote_unix.load_avg_5_minFive minute load averageCount
Load average (15 min)remote_unix.load_avg_15_min15 minute load averageCount
Network bytes receievedremote_unix.network_bytes_received_countNetwork traffic (in bytes) incoming per interfaceByte
Network packets receivedremote_unix.packets_received_countNetwork traffic (in Packets) incoming per interfaceCount
Network errors incomingremote_unix.network_errors_incoming_countNetwork errors on incoming traffic per interfaceCount
Packets dropped incomingremote_unix.packets_dropped_incoming_countIncoming packets dropped per interfaceCount
Network bytes sentremote_unix.network_bytes_sent_countOutbound network traffic (in bytes) per interfaceByte
Network packets sentremote_unix.packets_sent_countOutbound network traffic (in packets) per interfaceCount
Network errors outgoingremote_unix.network_errors_outgoing_countNetwork errors on outgoing traffic per interfaceCount
Packets dropped outgoingremote_unix.packets_dropped_outgoing_countOutgoing packets dropped per interfaceCount
Disk latency (average)remote_unix.disk_average_latencyDisk latency (average)MilliSecond
Full version history
ReleaseDate
Changes
  • Configuration option to only collect local mounts
  • Longer connection timeouts allowed when using persisted connection
  • More connection debugging options available
  • Reclaimable memory now considered for AIX memory metrics
  • 'Do not merge' property set on availability event when unable to connect
  • Detection of hangs when reading from standard output
Fixes
  • df output now correctly reports sizes using base 2 interpretation of command output on Solaris and AIX (e.g. 1K = 1024 bytes instead of 1000 bytes as in base 10). This will result in a slight increase in the values of absolute metrics though the percentage will stay the same. Note that despite this, the Dynatrace UI still uses base 10 for the units so while the number of bytes will be the same you may see different numbers because the UI would show Gigabytes while the df command outputs Gibibytes.
  • considers buffer and cache space in reporting available memory on some older Unix distributions
  • handles reporting of values with the largest units (E, Z, and Y)
  • fix bug in reporting of MacOS disk transfers metric
  • adds missing metric metadata for some MacOS-specific metrics
  • Corrects issue in build process that would prevent the previous 2.2.7 version from running on old ActiveGate OSs (e.g. RHEL 7.9)
  • Sets source entity metadata for all metrics to work with management zones
  • Default the optional remote host group value to "default"
    • Primarily to ensure metric tables/charts/selectors will not break when not set
  • Fixes bug in AIX where certain output of the 'df' command could cause processing of mount data to break
  • Increases filtered process pattern length limit to 1000
  • New Solaris Z Pools feature set
  • Scalability-focused features
    • Monitoring configuration-wide 'default' authentication possible
    • Configuration available for a 'remote host group' entity to help with organizing remote unix entities
    • Raises endpoint limit to 500
    • Must use the new Task bucket size configuration to break the endpoints into smaller assignable task units
  • Fix for issue on AIX where memory metric absolute values were incorrectly scaled to be larger than their actual values (did not affect 'percentage' based metrics)
  • Fix issue for some distributions that would result in missing data for the disk-level "bytes written" metric
  • New 'extended-disk' feature set
    • Supported for most 'standard' Debian based Linux distributions
    • Includes an additional run of iostat with the 'extended' option to report latency
  • Attempts to include IP addresses and a detected hostname property
    • Restore behavior present in original 1.0 extension
  • Fix issue where configured key path may not have properly been used for authentication
  • Fix bug with how failures in the fastcheck would be reported in some scenarios
  • Initial public release
Dynatrace Hub
All (716)Log Management and AnalyticsKubernetesAI/ML ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityDigital ExperienceBusiness Analytics
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Analyze abnormal system behavior and performance problems detected by Davis AI.
Logs logo
Logs
Security Investigator logo
Fast and precise forensics for security and logs on Grail data with DQL queries.
Business Flow logo
Business Flow
Carbon Impact logo
Carbon Impact
Provides the information about site's carbon footprint
Davis Anomaly Detection logo
Detect anomalies in timeseries using the Davis AI
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Automate tasks in your IT landscape, remediate problems, and visualize processes
Jira for Workflows logo
Jira for Workflows
Slack logo
Slack
Secure your cloud application
Security Overview logo
Security Overview
Get a comprehensive overview of the security of your applications.
Third-Party Vulnerabilities logo
Detect vulnerabilities in real time, with context and automated risk assessment.
Code-Level Vulnerabilities logo
Detect vulnerabilities in your code in real time.
Attacks logo
Attacks
Get a real-time overview of all the attacks on your environment.
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
