Licensing
There is no charge for obtaining the extension, only for the data (metrics & events) that the extension ingests. The details of license consumption will depend on which licensing model you are using. This will either be Dynatrace classic licensing or the Dynatrace Platform Subscription (DPS) model.
Metrics
License consumption is based on the number of metric data points ingested. The following formula will provide approximate annual data points ingested. Note that this will be highly dependent and variable based on traffic volume and patterns in your environment. For this reason, it will likely be more meaningful to run the extension for a period of time to determine metric consumption and then multiply that to get usage for a longer period (e.g. 1 year.)
Calculation estimates yearly DDU usage:
Identity Management:
((2 * providers * registration types) + (user types) (3 * operation per mangaged object) + (3 * unique action operation and outcome) + (audit topics) + (3 * oject mappings)) * 525.6
Access Management:
(3 + (5 * unique sessions and outcomes) + (1 * authentication outcomes) + (3 * unique operations by token type) + (2 * grants by type) + (2 * types of token issued) + (2 * unique authorization evaluations)) * 525.6
Log records
Log management and analytics (powered by Grail)
License consumption is based on the size (in bytes) of data ingested & processed, retained, and queried so there is not a single formula to estimate the total consumption from this extension. Consult the log management and analytics documentation for details on the other dimensions that will effect license consumption.
Classic licensing
In the classic licensing model, log record ingestion will consume Davis Data Units (DDUs) at the rate of 100 DDUs per Gigabyte of log records ingested.
Log monitoring classic
In log monitoring classic, license consumption is based on the number of ingested log records.
Classic licensing
In the classic licensing model, log record ingestion will consume Davis Data Units (DDUs) at the rate of .0005 DDUs per ingested log record.
Multiply estimated ingested log records by .0005 to estimate DDU usage from log records.
