Active secondary reads MB satisfied from FC | oracle.exadata.FC_IO_BY_R_ACTIVE_SECONDARY | Number of megabytes for active secondary reads satisfied from flash cache | MegaByte |
Active secondary reads MB not satisfied from FC | oracle.exadata.FC_IO_BY_R_ACTIVE_SECONDARY_MISS | Number of megabytes for active secondary reads not satisfied from flash cache | MegaByte |
Active secondary read MBps not satisfied from FC | oracle.exadata.FC_IO_BY_R_ACTIVE_SECONDARY_MISS_SEC | Number of megabytes per second for active secondary reads not satisfied from flash cache | MegaBytePerSecond |
Active secondary read MBps satisfied from FC | oracle.exadata.FC_IO_BY_R_ACTIVE_SECONDARY_SEC | Number of megabytes per second for active secondary reads satisfied from flash cache | MegaBytePerSecond |
Disk writer MB read | oracle.exadata.FC_IO_BY_R_DISK_WRITER | Number of megabytes read from flash cache by disk writer | MegaByte |
Disk writer MBps read | oracle.exadata.FC_IO_BY_R_DISK_WRITER_SEC | Number of megabytes per second read from flash cache by disk writer | MegaBytePerSecond |
DW large reads MB from FC | oracle.exadata.FC_IO_BY_R_DW | Number of megabytes of large reads (DW) from flash cache | MegaByte |
DW large reads MBps from FC | oracle.exadata.FC_IO_BY_R_DW_SEC | Number of megabytes of large reads (DW) per second from flash cache | MegaBytePerSecond |
OLTP small reads MB due to keep misses | oracle.exadata.FC_IO_BY_R_MISS | Number of megabytes of small reads (OLTP) from disks because some of the requested data was not in flash cache | MegaByte |
DW large reads MB due to keep misses | oracle.exadata.FC_IO_BY_R_MISS_DW | Number of megabytes of large reads (DW) from disks because some of the requested data was not in flash cache | MegaByte |
DW large reads MBps due to keep misses | oracle.exadata.FC_IO_BY_R_MISS_DW_SEC | Number of megabytes of large reads (DW) per second from disks because some of the requested data was not in flash cache | MegaBytePerSecond |
OLTP small reads MBps due to keep misses | oracle.exadata.FC_IO_BY_R_MISS_SEC | Number of megabytes of small reads (OLTP) per second from disks because some of the requested data was not in flash cache | MegaBytePerSecond |
Bypass reads MB due to heavy load | oracle.exadata.FC_IO_BY_R_SKIP_FC_THROTTLE | Number of megabytes read from disk for IO requests that bypass FlashCache due to heavy load on FlashCache | MegaByte |
Bypass reads MBps due to heavy load | oracle.exadata.FC_IO_BY_R_SKIP_FC_THROTTLE_SEC | Number of megabytes read per second from disk for IO requests that bypass FlashCache due to heavy load on FlashCache | MegaBytePerSecond |
Bypass reads MB due to large IO size | oracle.exadata.FC_IO_BY_R_SKIP_LG | Number of megabytes read from disk for IO requests that bypass FlashCache due to the large IO size | MegaByte |
Bypass reads MBps due to large IO size | oracle.exadata.FC_IO_BY_R_SKIP_LG_SEC | Number of megabytes read per second from disk for IO requests that bypass FlashCache due to the large IO size | MegaBytePerSecond |
Bypass reads MBps | oracle.exadata.FC_IO_BY_R_SKIP_SEC | Number of megabytes read from disks per second for IO requests that bypass FlashCache | MegaBytePerSecond |
Disk writer MB written | oracle.exadata.FC_IO_BY_W_DISK_WRITER | Number of megabytes written to hard disks by disk writer | MegaByte |
Disk writer MBps written | oracle.exadata.FC_IO_BY_W_DISK_WRITER_SEC | Number of megabytes per second written to hard disks by disk writer | MegaBytePerSecond |
First write MB into FlashCache | oracle.exadata.FC_IO_BY_W_FIRST | Number of megabytes that are first writes into flash cache | MegaByte |
First write MBps into FlashCache | oracle.exadata.FC_IO_BY_W_FIRST_SEC | Number of megabytes per second that are first writes into flash cache | MegaBytePerSecond |
FC metadata writes MB | oracle.exadata.FC_IO_BY_W_METADATA | Number of megabytes that are flash cache metadata writes | MegaByte |
FC metadata writes MBps | oracle.exadata.FC_IO_BY_W_METADATA_SEC | Number of megabytes per second that are flash cache metadata writes | MegaBytePerSecond |
FC overwrite MB | oracle.exadata.FC_IO_BY_W_OVERWRITE | Number of megabytes that are overwrites into flash cache | MegaByte |
FC overwrite MBps | oracle.exadata.FC_IO_BY_W_OVERWRITE_SEC | Number of megabytes per second that are overwrites into flash cache | MegaBytePerSecond |
FC population writes MB due to read miss | oracle.exadata.FC_IO_BY_W_POPULATE | Number of megabytes that are population writes into flash cache due to read miss | MegaByte |
FC population writes MBps due to read miss | oracle.exadata.FC_IO_BY_W_POPULATE_SEC | Number of megabytes per second that are population writes into flash cache due to read miss | MegaBytePerSecond |
Bypass written MB due to heavy load | oracle.exadata.FC_IO_BY_W_SKIP_FC_THROTTLE | Number of megabytes written to disk for IO requests that bypass FlashCache due to heavy load on FlashCache | MegaByte |
Bypass write MBps due to heavy load | oracle.exadata.FC_IO_BY_W_SKIP_FC_THROTTLE_SEC | Number of megabytes written per second to disk for IO requests that bypass FlashCache due to heavy load on FlashCache | MegaBytePerSecond |
Bypass written MB due to large IO size | oracle.exadata.FC_IO_BY_W_SKIP_LG | Number of megabytes written to disk for IO requests that bypass FlashCache due to the large IO size | MegaByte |
Bypass write MBps due to large IO size | oracle.exadata.FC_IO_BY_W_SKIP_LG_SEC | Number of megabytes written per second to disk for IO requests that bypass FlashCache due to the large IO size | MegaBytePerSecond |
Bypass write MBps | oracle.exadata.FC_IO_BY_W_SKIP_SEC | Number of megabytes written to disk per second for IO requests that bypass FlashCache | MegaBytePerSecond |
Active secondary read IOPS not satisfied from FC | oracle.exadata.FC_IO_RQ_R_ACTIVE_SECONDARY_MISS_SEC | Number of requests per second for active secondary reads not satisfied from flash cache | PerSecond |
Active secondary read IOPS satisfied from FC | oracle.exadata.FC_IO_RQ_R_ACTIVE_SECONDARY_SEC | Number of requests per second for active secondary reads satisfied from flash cache | PerSecond |
Disk writer FC read IOPS | oracle.exadata.FC_IO_RQ_R_DISK_WRITER_SEC | Number of requests per second read from flash cache by disk writer | PerSecond |
DW large read hit IOPS | oracle.exadata.FC_IO_RQ_R_DW_SEC | Number of large reads (DW) per second satisfied from the flash cache | PerSecond |
DW large read miss IOPS | oracle.exadata.FC_IO_RQ_R_MISS_DW_SEC | Number of large reads (DW) per second that did not find all data in flash cache | PerSecond |
OLTP small read miss IOPS | oracle.exadata.FC_IO_RQ_R_MISS_SEC | Number of small reads (OLTP) per second that did not find all data in flash cache | PerSecond |
Bypass read IOPS due to heavy load | oracle.exadata.FC_IO_RQ_R_SKIP_FC_THROTTLE_SEC | Number of requests read from disk per second that bypassed FlashCache due to heavy load on FlashCache | PerSecond |
Bypass read IOPS due to large IO size | oracle.exadata.FC_IO_RQ_R_SKIP_LG_SEC | Number of requests read from disk per second that bypass FlashCache due to the large IO size | PerSecond |
Bypass read IOPS | oracle.exadata.FC_IO_RQ_R_SKIP_SEC | Number of requests read from disk per second that bypass FlashCache | PerSecond |
Disk writer HDD write IOPS | oracle.exadata.FC_IO_RQ_W_DISK_WRITER_SEC | Number of requests per second written to hard disks by disk writer | PerSecond |
First write into FlashCache IOPS | oracle.exadata.FC_IO_RQ_W_FIRST_SEC | Number of requests per second that are first writes into flash cache | PerSecond |
FC metadata writes IOPS | oracle.exadata.FC_IO_RQ_W_METADATA_SEC | Number of requests per second that are flash cache metadata writes | PerSecond |
FC overwrite IOPS | oracle.exadata.FC_IO_RQ_W_OVERWRITE_SEC | Number of requests per second that are overwrites into flash cache | PerSecond |
Population FC write IOPS due to read miss | oracle.exadata.FC_IO_RQ_W_POPULATE_SEC | Number of requests per second that are population writes into flash cache due to read miss | PerSecond |
Bypass write IOPS due to heavy load | oracle.exadata.FC_IO_RQ_W_SKIP_FC_THROTTLE_SEC | Number of requests written to disk per second that bypass FlashCache due to heavy load on FlashCache | PerSecond |
Bypass write IOPS due to large IO size | oracle.exadata.FC_IO_RQ_W_SKIP_LG_SEC | Number of requests written to disk per second that bypass FlashCache due to the large IO size | PerSecond |
Bypass write IOPS | oracle.exadata.FC_IO_RQ_W_SKIP_SEC | Number of requests written to disk per second that bypass FlashCache | PerSecond |
