Otelcol Exporter Send Failed Metric Points | otelcol_exporter_send_failed_metric_points.count | Number of metric points in failed attempts to send to destination. [alpha] | Unspecified |
Otelcol Exporter Send Failed Spans | otelcol_exporter_send_failed_spans.count | Number of spans in failed attempts to send to destination. [alpha] | Unspecified |
Otelcol Exporter Sent Metric Points | otelcol_exporter_sent_metric_points.count | Number of metric points successfully sent to destination. [alpha] | Unspecified |
Otelcol Exporter Sent Spans | otelcol_exporter_sent_spans.count | Number of spans successfully sent to destination. [alpha] | Unspecified |
Otelcol Fileconsumer Open Files | otelcol_fileconsumer_open_files | Number of open files | Unspecified |
Otelcol Processor Batch Timeout Trigger Send | otelcol_processor_batch_timeout_trigger_send.count | Number of times the batch was sent due to a timeout trigger | Unspecified |
Otelcol Receiver Accepted Metric Points | otelcol_receiver_accepted_metric_points.count | Number of metric points successfully pushed into the pipeline. [alpha] | Unspecified |
Otelcol Receiver Accepted Spans | otelcol_receiver_accepted_spans.count | Number of spans successfully pushed into the pipeline. [alpha] | Unspecified |
Otelcol Receiver Refused Metric Points | otelcol_receiver_refused_metric_points.count | Number of metric points that could not be pushed into the pipeline. [alpha] | Unspecified |
Otelcol Receiver Refused Spans | otelcol_receiver_refused_spans.count | Number of spans that could not be pushed into the pipeline. [alpha] | Unspecified |
Promhttp Metric Handler Errors Total | promhttp_metric_handler_errors_total.count | Total number of internal errors encountered by the promhttp metric handler. | Unspecified |
Target Info | target_info | Target metadata | Unspecified |
Otelcol Exporter Queue Capacity | otelcol_exporter_queue_capacity | Fixed capacity of the retry queue (in batches) | Unspecified |
Otelcol Exporter Queue Size | otelcol_exporter_queue_size | Current size of the retry queue (in batches) | Unspecified |
Otelcol Exporter Send Failed Log Records | otelcol_exporter_send_failed_log_records.count | Number of log records in failed attempts to send to destination. | Unspecified |
Otelcol Exporter Sent Log Records | otelcol_exporter_sent_log_records.count | Number of log record successfully sent to destination. | Unspecified |
Otelcol Process Cpu Seconds | otelcol_process_cpu_seconds.count | Total CPU user and system time in seconds | Unspecified |
Otelcol Process Memory Rss | otelcol_process_memory_rss | Total physical memory (resident set size) | Unspecified |
Otelcol Process Runtime Heap Alloc Bytes | otelcol_process_runtime_heap_alloc_bytes | Bytes of allocated heap objects (see 'go doc runtime.MemStats.HeapAlloc') | Unspecified |
Otelcol Process Runtime Total Alloc Bytes | otelcol_process_runtime_total_alloc_bytes.count | Cumulative bytes allocated for heap objects (see 'go doc runtime.MemStats.TotalAlloc') | Unspecified |
Otelcol Process Runtime Total Sys Memory Bytes | otelcol_process_runtime_total_sys_memory_bytes | Total bytes of memory obtained from the OS (see 'go doc runtime.MemStats.Sys') | Unspecified |
Otelcol Process Uptime | otelcol_process_uptime.count | Uptime of the process | Unspecified |
Otelcol Processor Batch Batch Send Size | otelcol_processor_batch_batch_send_size | Number of units in the batch | Unspecified |
- | otelcol_processor_batch_batch_send_size_sum.count | - | - |
- | otelcol_processor_batch_batch_send_size_count | - | - |
Otelcol Processor Batch Batch Size Trigger Send | otelcol_processor_batch_batch_size_trigger_send.count | Number of times the batch was sent due to a size trigger | Unspecified |
Otelcol Processor Batch Metadata Cardinality | otelcol_processor_batch_metadata_cardinality | Number of distinct metadata value combinations being processed | Unspecified |
