Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
IBM DB2 for LUW (remote monitoring)IBM DB2 for LUW (remote monitoring)
Remotely collect monitoring metrics from your DB2 databases.
Extension
Free trialDocumentation
The DB2 Overview dashboard showing links to the different entity types and several metrics.The DB2 host entity analysis screen with several metrics of the underlying DB2 instances and links to the instances.DB2 data being injected into the OneAgent detected host screen when there is an IP address match detected between it and the extension discovered DB2 instance.The DB2 instance analysis screen with metrics related to the underlying DB2 member databases and links to them.The DB2 member analysis screen.The DB2 tablespace analysis screen.Instance properties with various HADR properties visible.Top current queries being reported on the DB2 instance entity.
  • Product information
  • Release notes
Overview
Remotely monitor DB2 databases to complement information collected by OneAgent.
Compatibility information
IBM supported versions of IBM DB2 for Linux, UNIX, and Windows (LUW) running on AIX, HP-UX, Linux, Solaris, or Windows are supported. DB2 for IBM i is not supported.
Refer to the IBM documentation for details on DB2 end of support dates.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Extension content
Content typeNumber of items included
metric query
16
screen logs cards
1
screen injections
1
screen layout
8
list screen layout
4
alerts
1
document dashboard
1
screen entities lists
8
metric metadata
80
dashboards
1
generic type
4
generic relationship
6
screen properties
4
screen chart groups
24
Feature sets
Availabilitydb2.availabilityAvailability based on ability of extension to connect to DB2 instance (100% reported on success, no data on failure).Percent
CPU usagedb2.cpu_usage_totalThe overall processor usage on this host including kernel processing time, expressed as a percentage.Percent
Memory freedb2.memory_freeThe total amount of physical memory on this host that is not allocated to a running process.MegaByte
Memory totaldb2.memory_totalThe total amount of physical memory on this host.MegaByte
Memory usagedb2.memory_usageThe total amount of physical memory on this host allocated to a running process as a percentage.Percent
Database manager instance statusdb2.db2_statusThe current status of the instance of the database manager.State
Member statusdb2.db_statusThe current status of the database member.State
Apps currently connecteddb2.appl_cur_consIndicates the number of applications that are currently connected to the database.Count
Dynamic SQL statementsdb2.dynamic_sql_stmts.countThe number of dynamic SQL statements that were attempted.Count
Failed SQL statementsdb2.failed_sql_stmts.countThe number of SQL statements that were attempted, but failed.Count
Total app commitsdb2.total_app_commits.countTotal number of commit statements issued by the client application.Count
Internal commitsdb2.int_commits.countThe total number of commits initiated internally by the database manager.Count
App rollbacksdb2.total_app_rollbacks.countTotal number of rollback statements issued by the client application.Count
Internal rollbacksdb2.int_rollbacks.countThe total number of rollbacks initiated internally by the database manager.Count
CPU timedb2.total_cpu_time.countThe total amount of CPU time used while within the database system. Represents total of both user and system CPU time.MicroSecond
Wait timedb2.total_wait_time.countThe total time spent waiting within the database server.MicroSecond
Request timedb2.total_rqst_time.countThe total amount of time spent working on requests.MilliSecond
Rows returneddb2.rows_returned.countThe number of rows that have been selected and returned to the application.Count
Rows readdb2.rows_read.countThe number of rows read from the tables.Count
Rows updateddb2.rows_updated.countThis is the number of row updates attempted.Count
Rows deleteddb2.rows_deleted.countThis is the number of row deletions attempted.Count
Rows inserteddb2.rows_inserted.countThe number of row insertions attempted.Count
Lock wait timedb2.lock_wait_time.countThe total elapsed time spent waiting for locks.MilliSecond
Deadlocksdb2.deadlocks.countThe total number of deadlocks that have occurred.Count
Lock timeoutsdb2.lock_timeouts.countThe number of times that a request to lock an object timed out instead of being granted.Count
Buffer pool data writesdb2.pool_data_writes.countThe number of times a buffer pool data page was physically written to disk.Count
Buffer pool index writesdb2.pool_index_writes.countIndicates the number of times a buffer pool index page was physically written to disk.Count
Buffer pool XDA writesdb2.pool_xda_writes.countIndicates the number of times a buffer pool data page for an XML storage object (XDA) was physically written to disk.Count
Local buffer pool index pages founddb2.pool_index_lbp_pages_found.countIndicates the number of index pages which have been synchronously read by agents and asynchronously read by prefetchers from the local buffer pool (logical) for regular and large table spaces.Count
Async local buffer pool index pages founddb2.pool_async_index_lbp_pages_found.countThe number of times an index page was present in the local buffer pool when a prefetcher attempted to access it.Count
Buffer pool index logical readsdb2.pool_index_l_reads.countIndicates the number of index pages which have been synchronously read by agents from the buffer pool (logical) for regular and large table spaces.Count
Buffer pool temp index logical readsdb2.pool_temp_index_l_reads.countIndicates the number of index pages which have been requested from the buffer pool (logical) for temporary table spaces.Count
Local buffer pool data pages founddb2.pool_data_lbp_pages_found.countIndicates the number of data pages which have been synchronously read by agents and asynchronously read by prefetchers from the local buffer pool (logical) for regular and large table spaces.Count
Async local buffer pool data pages founddb2.pool_async_data_lbp_pages_found.countThe number of times a data page was present in the local buffer pool when a prefetcher attempted to access it.Count
Buffer pool data logical readsdb2.pool_data_l_reads.countIndicates the number of data pages which have been synchronously read by agents from the buffer pool (logical) for regular and large table spaces.Count
Buffer pool temp data logical readsdb2.pool_temp_data_l_reads.countIndicates the number of data pages which have been requested from the buffer pool (logical) for temporary table spaces.Count
Local buffer pool XDA pages founddb2.pool_xda_lbp_pages_found.countIndicates the number of data pages for an XML storage object (XDA) which have been synchronously read by agents and asynchronously read by prefetchers from the local buffer pool (logical) for regular and large table spaces.Count
Async local buffer pool XDA pages founddb2.pool_async_xda_lbp_pages_found.countThe number of times a data page for an XML storage object (XDA) was requested by a prefetcher from and found in the local buffer pool.Count
Buffer pool XDA logical readsdb2.pool_xda_l_reads.countIndicates the number of data pages for XML storage objects (XDAs) which have been synchronously read by agents from the buffer pool (logical) for regular and large table spaces.Count
Buffer pool temp XDA logical readsdb2.pool_temp_xda_l_reads.countIndicates the number of pages for XML storage object (XDA) data which have been requested from the buffer pool (logical) for temporary table spaces.Count
Buffer pool data physical readsdb2.pool_data_p_reads.countIndicates the number of data pages which have been synchronously read by agents and asynchronously read by prefetchers from the table space containers (physical) for regular and large table spaces.Count
Buffer pool index physical readsdb2.pool_index_p_reads.countIndicates the number of index pages which have been synchronously read by agents and asynchronously read by prefetchers from the table space containers (physical) for regular and large table spaces.Count
Buffer pool XDA physical readsdb2.pool_xda_p_reads.countIndicates the number of data pages for XML storage objects (XDAs) which have been synchronously read by agents and asynchronously read by prefetchers from the table space containers (physical) for regular and large table spaces.Count
Buffer pool temp data physical readsdb2.pool_temp_data_p_reads.countIndicates the number of data pages read in from the table space containers (physical) for temporary table spaces.Count
Buffer pool temp index physical readsdb2.pool_temp_index_p_reads.countIndicates the number of index pages read in from the table space containers (physical) for temporary table spaces.Count
Buffer pool temp XDA physical readsdb2.pool_temp_xda_p_reads.countIndicates the number of pages for XML storage object (XDA) data read in from the table space containers (physical) for temporary table spaces.Count
Buffer pool victim page cleaners triggereddb2.pool_drty_pg_steal_clns.countThe number of times a page cleaner was invoked because a synchronous write was needed during the victim buffer replacement for the database.Count
Total sortsdb2.total_sorts.countThe total number of sorts that have been executed.Count
Time since backupdb2.time_since_backupTime since last backup was completedMinute
Backup timedb2.backup_time.countThe elapsed time that was spent doing online backupsMilliSecond
Online backupsdb2.total_backupsTotal number of online backupsCount
HADR connect statusdb2.hadr_connect_statusThe current high availability disaster recovery (HADR) connection status of the database.State
HADR statedb2.hadr_stateThe current high availability disaster recovery (HADR) state of the database.State
HADR log gapdb2.hadr_log_gapThe recent average of the gap between the PRIMARY_LOG_POS value and STANDBY_LOG_POS value (how far the standby is behind the primary).Byte
Standby tablespace errordb2.hadr_standby_tablespace_errorReports 1 if HADR_FLAGS indicate the standby database has a tablespace in an invalid error state. If this state occurs during a database upgrade and if the problem is not resolved before the upgrade completes, the table spaces that are in error will not be recoverable.State
Active connectionsdb2.active_connectionsCurrent active connections to database.Count
Log write timedb2.log_write_time.countThe total elapsed time spent by the logger writing log data to the disk.MilliSecond
Transaction log useddb2.total_log_usedThe total amount of active log space currently used in the database.Byte
Transaction log availabledb2.total_log_availableThe amount of active log space in the database that is not being used by uncommitted transactions.Byte
In doubt transactionsdb2.num_indoubt_transactionsThe number of outstanding indoubt transactions in the database.Count
Tablespace total pagesdb2.tbsp_total_pagesTotal number of pages in a table space.Count
Tablespace used pagesdb2.tbsp_used_pagesThe total number of pages that are currently used (not free) in a table space.Count
Tablespace statedb2.tbsp_stateThe current state of a table space.State
Full version history
ReleaseDate
Minimum Dynatrace version 1.312!
Changes
  • Includes platform dashboard
  • Adds security context to all entity types
Features
  • New configuration variable to control the frequency of metric collection
  • There is a now a SAME_AS relationship between a DB2 instance and its Process Group Instance
    • Listening port and detected address of DB2 PGI must match the hostname/IP and port used for extension device connection
Fixes
  • Corrects func:db2.total_log_utilization formula
New features
  • An alias can be configured per DB2 instance
    • Name will be used as the DB2 instance entity name as well as incorporated into the names of child entities
    • Entity IDs will not be affected so will have historical continuity with existing entities
  • New db2.hadr_standby_tablespace_error metric in HADR feature set. See DB2 documentation for an explanation of the scenario this detects.
  • Definitions to make AppEngine ready
  • Corrects source entity metadata for DB2 Host entity
    • Will correct issues where DB2 host metrics were not showing up in management zones
  • fix issue that would prevent HADR metrics from displaying on the DB2 Instance Unified Analysis screen
Minimum ActiveGate version required: 1.260
  • Introduces the first 'query-level' visibility with 'the top_current_sql' feature set. Enabling this will result in a query to the MON_CURRENT_SQL view and ingestion of log records for the top 50 currently executing statements (based on elapsed time) once every 5 minutes. As this may result in large amounts of additional data ingestion be sure to use with caution.
  • Includes backup metrics in the existing 'database' feature set:
    • Time since last backup
    • Backup time
    • Number of online backups
  • 1.1.2 was a major change so be sure to review those earlier release notes as well if updating from an earlier version
  • Fixes an issue with the 'source entity type' for several metrics (hadr and db2 status) that would cause issues with metrics missing from management zones
Note: this version has changes to the tables and views that are queried. Review the latest requirements on the Hub page for details on what permissions are needed prior to updating
  • Connection metrics now in dedicated feature set
    • Be sure to enable this when updating if you want connection metrics
  • HADR metrics and properties are now collected
    • HADR feature set must be enabled
  • Tablespaces now have their own entity type rather than having tablespace metrics associated with the member entity
    • If you have rules such as metric events for tablespace metrics that were filtered by the member entity be sure to review if you need to update these
    • The new tablespace entity has various new properties that can be used such as their state and whether auto resize is enabled
  • New in-doubt transaction metric collected in transaction_log feature set
  • Basic host resource metrics (CPU and memory) are now collected
  • The db2.metadata metric is no longer used/needed
    • This has been consolidated into the host resources query
  • DB2 status is now reported
  • Fix to instance level metric metadata that would have prevented management zone filtering from working for these metrics
  • Various screen fixes and adjustments
  • Collects active connection metric
    • Requires enabling the 'connections' feature set
  • Initial GA release
  • Three feature sets:
    • Database
    • Transaction logs
    • Tablespace
  • UI Screens for DB2 entities
  • Overview dashboard
  • 'Availability' metric event
Dynatrace Hub
All (812)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityDigital ExperienceBusiness Observability
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Analyze abnormal system behavior and performance problems detected by Davis AI.
Logs logo
Logs
Security Investigator logo
Fast and precise forensics for security and logs on Grail data with DQL queries.
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Davis Anomaly Detection logo
Detect anomalies in timeseries using the Davis AI
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Automate tasks in your IT landscape, remediate problems, and visualize processes
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Overview logo
Security Overview
Get a comprehensive overview of the security of your applications.
Code-Level Vulnerabilities logo
Detect vulnerabilities in your code in real time.
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Observability for Developer on Jetrains logo
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
