Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Google App Engine (integration)Google App Engine (integration)coming soon
coming soon
Insights into Google App Engine service metrics collected from Operations API
Extension
  • Product information
  • Release notes
Overview
This Dynatrace extension leverages data collected from the Google Operations API to constantly monitor health and performance of Google App Engine services. This extension combines all relevant data into pre-configured dashboards and provides alerting and event tracking.
This is intended for users, who want to:
  • enrich their monitoring data with metrics and logs from Google Operations API
This enables you to:
  • View and analyze 40 metrics that are specific to Google App Engine, like Monitoring Agent API Request Count, Logging Agent Log Entry Count, Logging Agent Retried Log Entry Writes Count, and more.
  • Build custom dashboards for your cloud infrastructure.
  • Analyze Google App Engine logs.
  • Use preconfigured alerting.
  • Set custom alerts that trigger remediation workflows.
Google App Engine metric and log ingestion requires advanced GCP integration.
Compatibility requirements
  • Dynatrace GCP integration version 1.0.0+. To enable metric and log ingestion, see Dynatrace Documentation.
  • Dynatrace version 1.256+
Details
This extension package contains:
  • Configuration for Google App Engine metric ingest based on your selected feature set (see the full list of feature sets and metrics)
  • Topology mapping and service instance analysis view
  • Google App Engine predefined alerts for: Google App Engine Application CPU utilization [GCP], Google App Engine Instance CPU Utilization [GCP]
To provide correlation and causation analysis all ingested metrics and logs are analyzed by the Dynatrace Davis AI engine, which consumes DDUs.
Get started
To add this extension to your environment:
  • Follow the instructions detailed in Dynatrace Documentation. (Ignore the “Add to environment” button below.)
  • Ensure that you have GCP integration running in your environment and that Google App Engine service is configured.
Following GCP integration and Google App Engine configuration:
  • The first data points will be ingested by Dynatrace Davis within ~5 minutes.
  • Explore Google App Engine metrics in Data Explorer and create custom charts.
  • Activate predefined alerting or set custom events for alerting
Provided by
Dynatrace
Support
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Extension content
Content typeNumber of items included
alerts
2
metric metadata
40
screen injections
1
generic relationship
1
screen actions
1
screen layout
1
generic type
2
screen entities lists
1
Feature sets
Monitoring Agent API Request Countcloud.gcp.agent_googleapis_com.agent.gae_app.api_request_count-Count
Logging Agent Log Entry Countcloud.gcp.agent_googleapis_com.agent.gae_app.log_entry_count-Count
Logging Agent Retried Log Entry Writes Countcloud.gcp.agent_googleapis_com.agent.gae_app.log_entry_retry_count-Count
Monitoring Agent Memory Usagecloud.gcp.agent_googleapis_com.agent.gae_app.memory_usage-Byte
Monitoring Agent Metric Point Countcloud.gcp.agent_googleapis_com.agent.gae_app.monitoring.point_count-Count
Logging Agent API Request Countcloud.gcp.agent_googleapis_com.agent.gae_app.request_count-Count
Monitoring Agent Process Labels Sizecloud.gcp.agent_googleapis_com.agent.gae_app.streamspace_size-Byte
Monitoring Agent is Throttling Processescloud.gcp.agent_googleapis_com.agent.gae_app.streamspace_size_throttling-Count
Monitoring/Logging Agent Uptimecloud.gcp.agent_googleapis_com.agent.gae_app.uptime.count-Second
Autoscaling Metrics Utilization Capacitycloud.gcp.appengine_googleapis_com.flex.autoscaler.capacity-Count
Autoscaling Metrics Current Utilizationcloud.gcp.appengine_googleapis_com.flex.autoscaler.current_utilization-Count
Connectionscloud.gcp.appengine_googleapis_com.flex.connections.current-Count
Reserved corescloud.gcp.appengine_googleapis_com.flex.cpu.reserved_cores-Count
CPU utilizationcloud.gcp.appengine_googleapis_com.flex.cpu.utilization-Percent
Disk bytes readcloud.gcp.appengine_googleapis_com.flex.disk.read_bytes_count-Byte
Disk bytes writtencloud.gcp.appengine_googleapis_com.flex.disk.write_bytes_count-Byte
Network bytes received.cloud.gcp.appengine_googleapis_com.flex.network.received_bytes_count-Byte
Network bytes sent.cloud.gcp.appengine_googleapis_com.flex.network.sent_bytes_count-Byte
Interception countcloud.gcp.appengine_googleapis_com.http.server.dos_intercept_count-Count
Quota denial countcloud.gcp.appengine_googleapis_com.http.server.quota_denial_count-Count
Response countcloud.gcp.appengine_googleapis_com.http.server.response_count-Count
Response latencycloud.gcp.appengine_googleapis_com.http.server.response_latencies-MilliSecond
Response count by stylecloud.gcp.appengine_googleapis_com.http.server.response_style_count-Count
Memcache utilizationcloud.gcp.appengine_googleapis_com.memcache.centi_mcu_count-Count
Hit ratiocloud.gcp.appengine_googleapis_com.memcache.hit_ratio-Count
Memcache operationscloud.gcp.appengine_googleapis_com.memcache.operation_count-Count
Memcache received bytescloud.gcp.appengine_googleapis_com.memcache.received_bytes_count-Byte
Memcache sent bytescloud.gcp.appengine_googleapis_com.memcache.sent_bytes_count-Byte
Used Cache Sizecloud.gcp.appengine_googleapis_com.memcache.used_cache_size-Byte
Estimated instance countcloud.gcp.appengine_googleapis_com.system.billed_instance_estimate_count.gauge-Count
CPU megacyclescloud.gcp.appengine_googleapis_com.system.cpu.usage-Count
Instance countcloud.gcp.appengine_googleapis_com.system.instance_count.gauge-Count
Memory usagecloud.gcp.appengine_googleapis_com.system.memory.usage-Byte
Received bytescloud.gcp.appengine_googleapis_com.system.network.received_bytes_count-Byte
Sent bytescloud.gcp.appengine_googleapis_com.system.network.sent_bytes_count-Byte
Connectionscloud.gcp.appengine_googleapis_com.flex.instance.connections.current-Count
CPU Utilizationcloud.gcp.appengine_googleapis_com.flex.instance.cpu.utilization-Percent
Network bytes receivedcloud.gcp.appengine_googleapis_com.flex.instance.network.received_bytes_count-Byte
Network bytes sentcloud.gcp.appengine_googleapis_com.flex.instance.network.sent_bytes_count-Byte
Websocket average durationcloud.gcp.appengine_googleapis_com.flex.instance.ws.avg_duration-Second
Related to Google App Engine (integration)
Google App Engine logo
Google App Engine
Service and cloud computing platform for developing and hosting web applications.
Full version history
ReleaseDate
Version 1.1.4
Updated
  • Added log linking to entities
Version 1.1.3
Updated
  • Feature sets & metrics section in HUB Product Information page
Version 1.1.2
Fixed
  • GCP project details page doesn't crash anymore when cloud:gcp:gae_app type is not declared in environment
Version 1.1.1
Changed
  • Each multiservice metric (agent.googleapis.com/agent) split to separate metrics - one per entity type (for sake of management-zone filtering support)
Version 1.1.0
Added
  • Metrics now support management-zone filtering (main entity type specified for metrics)
Version 1.0.3
Added
  • Release notes to published extension
  • Auto publishing extensions to Hub
Support for GCP overview
No release notes
Dynatrace Hub
All (751)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityDigital ExperienceBusiness Analytics
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Analyze abnormal system behavior and performance problems detected by Davis AI.
Logs logo
Logs
Security Investigator logo
Fast and precise forensics for security and logs on Grail data with DQL queries.
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Davis Anomaly Detection logo
Detect anomalies in timeseries using the Davis AI
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Automate tasks in your IT landscape, remediate problems, and visualize processes
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Overview logo
Security Overview
Get a comprehensive overview of the security of your applications.
Third-Party Vulnerabilities logo
Detect vulnerabilities in real time, with context and automated risk assessment.
Code-Level Vulnerabilities logo
Detect vulnerabilities in your code in real time.
Attacks logo
Attacks
Get a real-time overview of all the attacks on your environment.
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
