Managing highly dynamic service and application infrastructures with a CMDB database can be cumbersome and error prone. Modern microservices infrastructures commonly contain thousands of individual business-critical services and related dependencies. Dynatrace automatically discovers and monitors all such services and applications in real time, detects deviations from normal behavior (availability, performance, and/or errors), and synchronizes this data with your ServiceNow instance.
Dynatrace anomaly detection
The first step toward gaining full technology insight into each individual service request of each of your customers is to install Dynatrace OneAgent on your hosts. Once installed, OneAgent automatically discovers all software services and applications running on your host and detects all communication relationships between your services in real time.
Dynatrace immediately calculates a multi-dimensional baseline with up to 10K cells for each service and application in your environment. This baseline allows Dynatrace to automatically detect degradations from normal behavior and inform you about complex problems and any impact on customer experience. Problems include detail related to all affected services and applications, their relationships, as well as root cause information that is correlated with each individual service.
Dynatrace ServiceNow CMDB synchronization
With the new Dynatrace ServiceNow CMDB synchronization application, all auto-discovered hosts, applications, and services—along with their relationships—can be synchronized with your ServiceNow ITIL CMDB database.
The main benefits of seamless integration between Dynatrace and your ServiceNow instance are:
- Automatic synchronization of auto-detected services and applications, along with their
used_by
relationships, in real time. - Automatic synchronization of monitored hosts and virtual machines, along with their attributes.
- Automatic push of Dynatrace-detected problems in your monitored infrastructure to your ServiceNow incidents list.
- Automatic linking of detected problems with all affected CMDB CIs.
The image below compares how the synchronization of a Dynatrace-discovered application and its relationships to auto-discovered business-critical services looks in Dynatrace Smartscape and how it looks when synchronized within the ServiceNow dependency map.
For more detail on synchronizing Dynatrace monitoring with ServiceNow, see How do I set up ServiceNow problem notifications?
Looking for answers?
Go to forum
